475rwhp 415rwtq ls6 engine for sale or part out
UPDATE: 7/12/18 sorry guys cars been on the back burner have not even looked at it in a while, engine is still in the car and the car is sitting on my trailer and the 416 short block is needing to be assembled but got side tracked since i been modding my harley and having fun with it, but this has to get done so...
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- grab coffee or a beer this is a long story but i want potential buyers to fully know what im offering! this engine has less then 60k on the bottom end (cars has 58,xxx) when i bought the car a few years ago (52,xxx miles) i installed heads and cam tuned it car made 450ish hp 380ish tq didnt like the cam so about 3k miles ago i re-cammed the car (about 55k miles) at that time i installed new from GM ls2 timing chain, ls6 oil pump re dyno'd car made 475/415 rear wheel tracked the car best of 11.21 @ 121mph (i think # 11 on the zo6 fast list) very street friendly daily it in the summer i did install nitrous on the car only 1.5 bottles on the engine thanks to the national nitrous shortage but made 599/600 rear wheel (no passes on nitrous so no times) mostly it was on the dyno while tuning and one night 2 pulls on the highway last summer the timing chain let go car just sat unlil about 10 days ago i was fixing it and one head bolt stripped out (last one passenger side under valve cover) so the engine has to come out to repair it i always told myself if this engine has to come out id forge the bottom end well a while back i bought a L92 that needs rebuilding just because it was to cheap to leave i had intentions of putting it in my pickup but since this happen decided on 416 for my zo6 so selling this ls6 engine details! when the chain snapped some valves got bent and marked some of the pistons a little, i talked to a few guys even the one who redone my heads they all said bottom end was good to use (hence me reinstalling the heads) repair! seams this is very common on aluminum blocks there is 2 options for fixing this option #1 have the block drilled/tap for 1/2" head studs options #2 install a time sert in the stripped hole $40 or have all the head bolt holes done for $500 up until now i never herd about using time sert's i was told its common with import engines like bmw, mercadies benz & so on very strong and lasting repair im being told if i didnt have the L92 on hand id fix it and use it what your getting ls6 bottom end with less then 60k miles btr stage 2 ls1 n/a cam 3k miles ls7 lifters 3k miles ls6 oil pump 3k miles PRC 2.5 cnc'd 243's just redone new valves, new seals valves, valves lapped spring pressures checked btr 660 dual springs upgrade trunnion rockers 3k miles brand new never ran btr 7.400 push rods ported fast 92mm intake manifold with fuel rail front cover rear cover valve covers GM head gaskets new installed but never ran new front cover gasket and crank seal installed never ran parts you WILL NOT be getting no sensors engine mounts water pump any of the belt drive no a/c compressor no fly wheel no oil pan no injectors no crank pulley no timing chain (sorry going on the new engine) so basically no parts that i can transfer to my new engine will NOT be sold $3,800 or best offer? buyer pays shipping & paypal fee's or send check (wont ship till check clears) im in the Chicago, IL. might be willing to travel some to meet buyer depending on distance if engine does not sell might part out, if your interested in any of it post what your wanting and your offer keep in mind this is a 475/415 setup in a manual car! i can include my tune file if you have hptuners i used 42lb injectors |
Just curious if you would be interested in parting with the intake manifold and is the throttle body available also? If so how much for both?
Originally Posted by SLVRVERT
(Post 1596951753)
Ok thanks for the reply and keep me posted as to what you decide. I am interested if the price is right. Thank you!:seeya
Would you be willing to send me your tune file? I just finished my engine and have HPTuners but I'm new at this so having something to reference would be helpful.
Originally Posted by Rondan1020
(Post 1596956502)
have you checked the hpt site? Repository section you can log in and search for setup like yours |
bump
Interested in the heads in case you part out.
What is the compressed thickness on the head gaskets? Are they the stock. 051ish?
dont remember but there stock GM MLS gaskets
I am interested in the cam if you decide to part out..if the price is right. Thanks
Parts
I'm interested in the Cam, Lifters, Pushrods, Trunnion upgraded rockers and the Oil Pump if you decide to part it out.
Thanks Harold |
I would be interested in the heads and intake if you want to part it out? |
Pic of engine please :cheers:
I’d like to buy the nitrous kit if your willing to split up |
bump for update!
Originally Posted by LS-Kid
(Post 1597579286)
i sent a message
still for sale
