Sold
https://cimg0.ibsrv.net/gimg/www.cor...a322e8f53.jpeg https://cimg7.ibsrv.net/gimg/www.cor...1dd8510c5.jpeg Bought wrong one for my car. Trying to make a quick sale. It’s brand new. Apparently mine takes the ZR1 unit. 675 and can work put shipping if not local. |
Originally Posted by mayracn
(Post 1597300084)
It is indeed the wrong radiator. I have oil cooler in radiator. The zr1 radiator is the one I need. This is the one that will fit most z06’s. |
Where are you located |
Phoenix, Az
Originally Posted by duhveed
(Post 1597301020)
(Post 1597301027)
Phoenix, Az |
(Post 1597300953)
Yes its 1139105A.
(Post 1597301078)
thanks happen to have the part number? |
Yea I didn’t see that till I went to remove it. I’m 2011 with this so of course has to be difficult.
Originally Posted by LeftLane Z06
(Post 1597301113)
yup...zr1 has another coolant nipple on the lower driver side of the radiator.
C6 CORVETTE
RADIATOR ONLY Model: 1139105A (One Cooler) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This radiator includes the correct factory type "quick connect" fittings for the oil connections. Application : Use with all Z06 & C6 Automatic, LS3 with Dry Sump NOTE: Excludes 2012 spl Z07 Model: 1139105B (Both Coolers) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This heavy duty radiator features both an EOC (left side) and TOC (right side). Application : This is a true Direct Fit® for 2005 & 2009 Z51 option cars. (2007-09 wet sump motor used 1139105B, All Dry Sump Cars use model: 1139105A) Model: 1139105M (No Coolers) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. Application: Use with Non-Z51,base cars with manual transmission only. Model: 1139105E (EOC Only) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This model features a high performance 7 plate aluminum engine oil cooler for those wanting to upgrade to engine oil cooling. Oil ports are 3/4-16 SAE which are identical to the factory GM radiator. You can use the factory GM oil line assembly (quick connection fttings required) or install the #10AN fittings and use SS hose assemblies. Application: No factory option Model: 1139109Z (ZR1) Our new radiator for 2009-2013 ZR1 option Corvettes. This radiator is also used on 2012 Z06 with special Z07 option. RADIATOR & FAN COMBINATIONS Model: 4139105A (TOC Only) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This radiator includes the correct factory type "quick connect" fittings for the transmission oil connections. All Z06 & C6 Automatic NOTE: Excludes 2012 spl Z07 Model: 4139105B (Both Coolers) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This heavy duty radiator features both an EOC (left side) and TOC (right side). This is a true Direct Fit® for 2005 - 2009 Z51 option cars. 2007-09 Wet sump motors (All Dry Sump Cars use model: 4139105A) Model: 4139105M (No Coolers) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. Use with Non-Z51,base cars with manual transmission only. Model: 4139105E (EOC Only) This Direct Fit® radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This model features a high performance 7 plate aluminum engine oil cooler for those wanting to upgrade to engine oil cooling. Oil ports are 3/4-16 SAE which are identical to the factory GM radiator. You can use the factory GM oil line assembly (quick connection fttings required) or install the #10AN fittings (included) and use SS hose assemblies. See Spal Fan Category for Model: SP463 Spals dual fan package boosts air flow up 40% from stock. This fan package only fits our Direct Fit® radiators. Note: Factory wiring will need to be cut and spliced in order for the factory ECM to operate the fans. Title $649.99 USD Qty: 1 |
PM sent
Do you still have this?
Sold
sorry It’s sold |
