Rust...how bad is bad?
6 Attachment(s)
While waiting on Duntov to build/ship my rear & trailing arms I decided to inspect the existing rust on my 1978 C3. IMO it's no where as bad as others I've seen, but I would appreciate the experts' opinions.
It's not always possible to tell from photos, but it looks like you have nothing but surface rust. Now would be a good time to clean it up and get some paint on it to stop any future rust.
Mike |
There is nothing wrong with that frame, minor surface rust.
Thanks guys...I just stocked up on wire brushes and wire wheels. I'm also going to give VHT Rust Converter a shot.
its whats on the inside that will be worse. but you just have surface rust.. get you a paint wand or something and spray in the inside of your frame as much as you can whilst it is apart.
you can get to lots more that way |
Yeah mine looked like that. But it was fine. Then I painted everything.
:lurk:
Put an air nozzle inside the frame and blow it out. I think you'd be surprised at what blows around. I had rust chunks, mouse nests, a pen and some change come out when I did that just after I bought my car.
Blow rust inhibitor in the frame with a paint gun. It'll drip out, but It'll help. |
Originally Posted by Dodosmike
(Post 1597444702)
Looks like surface rust.
Get an ice pic and start stabbing LOL I just went through this with my frame and it looked worse than that but was solid as can be Eastwood has some great products to help, including a inside frame coating system They also have some large wire brushes that work well That said, beware of the temptation that will arise to pull the body off to get to it all. That is what happened to me. Glenn in San Diego |
POR-15 makes a great rust inhibiting system. That is what I use. Works great.
The problem with rust on our cars it's not usually the rust you can see that's the problem, it's the rust that you can't see because it's behind the fiberglass. The "birdcage" is where the nasty rust occurs because you can't see the effects of it like an all metal body car. While you are rust hunting I suggest you look at all the body mounts and take the kick panel off both sides and check #2 body mount. That should give you an indication of the general condition of the birdcage. To me your frame looks good. |
Originally Posted by theandies
(Post 1597446462)
The problem with rust on our cars it's not usually the rust you can see that's the problem, it's the rust that you can't see because it's behind the fiberglass. The "birdcage" is where the nasty rust occurs because you can't see the effects of it like an all metal body car. While you are rust hunting I suggest you look at all the body mounts and take the kick panel off both sides and check #2 body mount. That should give you an indication of the general condition of the birdcage. To me your frame looks good. DUB |
Where Im from, that doesn't even qualify as rust. Ive bought used cars from showrooms with bottom sides that look worse. Continue on with whatever other projects you may have. You dont have any rust to be concerned with. Thats just 'patina'.
I got under there today and wire brushed off all of the loose crap and hit with some rust converter. I just ordered a quart of POR-15 via Amazon. My trailing arms and half shafts arrive tomorrow. I still have until next week before my differential arrives, so that gives me a bit more time to clean up under there.
Mine looked like yours when I got it , I broke a wheel stud off one of the rear trailing arm axle , so I pulled it off to fix properly and it started ……..
ended up with this so be careful :) https://cimg7.ibsrv.net/gimg/www.cor...2b8bbfe0fb.jpg |
Originally Posted by bazza77
(Post 1597448127)
ended up with this so be careful :) |
Is that your workshop ? Unusual style of hoist there. Looks strong !:thumbs:
(Post 1597448243)
sounds good , is the steering box and idler arm good ? if so then its a as new front and will be a new rear .well done :thumbs:
