1971 amp gauge install
What is the easiest way to replace amp gauge that is broke?
Ted |
Easiest would be to pay someone else to do it. I know of no easy way to get to the rear of the cluster without removing it.
Amp gauge
So removing entire center console dash is only way, radio and all.
How do you know that the 'gauge' is what has failed? Your wiring connections could be defective, someone could have 'cabbaged-up' your wiring, a fusible link could be burned-out, etc.
You could test the meter without removing it from the cluster by locating the two feeder wires to that gauge, disconnecting one of them and momentarily touching a small 1.5v battery to those wires while watching for gauge movement. If the gauge needle moves, the gauge is probably OK. If it does not, you need to remove and repair/replace it. The simplest place to get to those two wires is at the wiring bulkhead connector on the engine side. If you can read an electrical wiring schematic, you can locate those two wires coming out of the engine bulkhead connector. I would estimate the odds of the gauge being the problem at 50%; one of the fusible links (there is a 20 awg orange fusible link connected to BOTH of those leads [one is inside the main wiring harness bundle and the other is at the horn relay]) 30%; and 20% probability going to other connected wiring {under dash or in engine compartment}. It would be a shame to buy and swap out that gauge...only to find out that it was OK and the problem was elsewhere. :( |
Amp gauge
Needle broke off. That is why needs replaced.
Amp gauge
Have two factory original gauges, amp and temp.
Put a voltmeter in instead. Originality is nice. Being able to tell you have a charging system is nicer...
Sorry, but that's not the best idea for an early C3 car. The wiring is there for the ammeter; and an ammeter will tell you things that a voltmeter will not...if you know how to read it.
Not sure how the needle broke off (????). Hope it wasn't due to some wild fluctuations with the gauge. You could install a voltmeter; but you would need to re-route some of the wiring as the later C3's had. |
1971 amp gauge
Thanks, amp gauge is going to be installed.
Not that hard to do your self . Remove the map section of the dash ie RHS then you can replace without removing the gauge panel . Bfit |
Amp gauge
What is map side of dash,
Map side
Have you ever changed that gauge by removing that side of dash?
Originally Posted by thelal1
(Post 1597452178)
Its easy to remove compared to removing the gauge panel. bfit |
Amp gauge
Have you ever replaced one like this,? What should I be careful of..?
(Post 1597454445)
Before anything else FIRST Disconnect the battery, both terminals When you are ready to disconnect the cables of the back of the gauge , mark the cables, so you know which goes where , an easy method to use , get a few different coloured ( Spelling I'm Australian ) zip ties , and draw your self a map of where each wire goes . Its a good idea to take photos, |
(Post 1597454445)
https://cimg6.ibsrv.net/gimg/www.cor...d38a371f60.jpg |
Originally Posted by bfit
(Post 1597453645)
passenger side dash section, glove box , Its easy to remove compared to removing the gauge panel. bfit |
Amp gauge
Noticed on oil gauge, it's wired. I thought on 71 it was oil line. May be wrong.
Thanks for the help. I have some small stickers and will take your advice. Ted |
"Noticed on oil gauge, it's wired. I thought on 71 it was oil line. " This is the back to just show the ammeter location and the metal backing plate that has to come off to replace the ammeter. On my 68 the oil pressure gauge has the small copper tubing. Not sure what year it changed to an electrical sending unit and electrical gauge.
(Post 1597463540)
