1971 amp gauge install
Old Jun 20, 2018 | 08:31 AM
thelal1's Avatar
thelal1
Default 1971 amp gauge install
What is the easiest way to replace amp gauge that is broke?
Ted
Old Jun 20, 2018 | 10:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Easiest would be to pay someone else to do it. I know of no easy way to get to the rear of the cluster without removing it.
Old Jun 20, 2018 | 11:02 AM
thelal1's Avatar
thelal1
Default Amp gauge
So removing entire center console dash is only way, radio and all.
Old Jun 20, 2018 | 11:11 AM
7T1vette's Avatar
7T1vette
How do you know that the 'gauge' is what has failed? Your wiring connections could be defective, someone could have 'cabbaged-up' your wiring, a fusible link could be burned-out, etc.
You could test the meter without removing it from the cluster by locating the two feeder wires to that gauge, disconnecting one of them and momentarily touching a small 1.5v battery to those wires while watching for gauge movement. If the gauge needle moves, the gauge is probably OK. If it does not, you need to remove and repair/replace it.
The simplest place to get to those two wires is at the wiring bulkhead connector on the engine side. If you can read an electrical wiring schematic, you can locate those two wires coming out of the engine bulkhead connector.
I would estimate the odds of the gauge being the problem at 50%; one of the fusible links (there is a 20 awg orange fusible link connected to BOTH of those leads [one is inside the main wiring harness bundle and the other is at the horn relay]) 30%; and 20% probability going to other connected wiring {under dash or in engine compartment}.
It would be a shame to buy and swap out that gauge...only to find out that it was OK and the problem was elsewhere.
Old Jun 20, 2018 | 11:44 AM
thelal1's Avatar
thelal1
Default Amp gauge
Needle broke off. That is why needs replaced.
Old Jun 20, 2018 | 11:45 AM
thelal1's Avatar
thelal1
Default Amp gauge
Have two factory original gauges, amp and temp.
Old Jun 20, 2018 | 07:46 PM
derekderek's Avatar
derekderek
Put a voltmeter in instead. Originality is nice. Being able to tell you have a charging system is nicer...
Old Jun 21, 2018 | 12:37 AM
7T1vette's Avatar
7T1vette
Sorry, but that's not the best idea for an early C3 car. The wiring is there for the ammeter; and an ammeter will tell you things that a voltmeter will not...if you know how to read it.
Not sure how the needle broke off (????). Hope it wasn't due to some wild fluctuations with the gauge. You could install a voltmeter; but you would need to re-route some of the wiring as the later C3's had.
Old Jun 21, 2018 | 02:05 AM
thelal1's Avatar
thelal1
Thanks, amp gauge is going to be installed.
Old Jun 21, 2018 | 02:13 AM
bfit's Avatar
bfit
Not that hard to do your self . Remove the map section of the dash
ie RHS then you can replace without removing the gauge panel .
Bfit
Old Jun 21, 2018 | 01:46 PM
thelal1's Avatar
thelal1
Default Amp gauge
What is map side of dash,
Old Jun 21, 2018 | 02:19 PM
thelal1's Avatar
thelal1
Default Map side
Have you ever changed that gauge by removing that side of dash?
Old Jun 21, 2018 | 05:12 PM
bfit's Avatar
bfit
passenger side dash section, glove box ,
Its easy to remove compared to removing the gauge panel.
bfit
Old Jun 21, 2018 | 07:06 PM
thelal1's Avatar
thelal1
Default Amp gauge
Have you ever replaced one like this,? What should I be careful of..?
Old Jun 22, 2018 | 01:12 AM
bfit's Avatar
bfit
Yes I had mine out a few years back.
Before anything else
FIRST Disconnect the battery, both terminals
When you are ready to disconnect the cables of the back of the gauge ,
mark the cables, so you know which goes where , an easy method to use , get a few different coloured ( Spelling I'm Australian ) zip ties , and draw your self a map of where each wire goes .
Its a good idea to take photos,
Old Jun 22, 2018 | 01:49 AM
Peterbuilt's Avatar
Peterbuilt
Loosen these bottom nuts first (or at least after you disconnect the battery as said before):
Old Jun 23, 2018 | 12:22 AM
ronarndt's Avatar
ronarndt
bfit
If you just remove the passenger side dash panel, you will be able to see where the ammeter is, but the metal backing plate that covers all of the gauges must be removed to remove and re-install the ammeter. There isn't enough room to get your hand back there to undo the fasteners. You can loosen the center console and tilt it back toward the rear of the car to get room to work on it, but it is much easier to carefully label all of the wires, remove the panel and work on your work bench so you do not drop the little screws down in the console. When re-installing the ammeter make sure the insulating strips are installed one on the inside of the metal backing plate and one on the outside of the backing plate so the two terminals on the ammeter do not touch the metal backing. If the terminals touch the metal backing, you will have a dead short and melt the fusible link on either the black wire or the black/white stripe wire. and the gauge will not work.
To 1971 amp gauge install
Old Jun 23, 2018 | 07:59 AM
thelal1's Avatar
thelal1
Default Amp gauge
Noticed on oil gauge, it's wired. I thought on 71 it was oil line. May be wrong.
Thanks for the help. I have some small stickers and will take your advice.
Ted
Old Jun 23, 2018 | 10:57 AM
ronarndt's Avatar
ronarndt
"Noticed on oil gauge, it's wired. I thought on 71 it was oil line. " This is the back to just show the ammeter location and the metal backing plate that has to come off to replace the ammeter. On my 68 the oil pressure gauge has the small copper tubing. Not sure what year it changed to an electrical sending unit and electrical gauge.
Old Jun 23, 2018 | 10:58 AM
62corvette's Avatar
62corvette
Ted
You are correct. 71 has a plastic oil line.
