LG/StopTech Big Brake Kit Now Available
For our upcoming Nurburgring trip Lou wanted the "Badass StopTech's" he used in WC, StopTech didn't have a C7 Application but after a little persuasion now they do! Give us a call at 972-429-1963 for more information or to order yours.
https://cimg5.ibsrv.net/gimg/www.cor...faf40c3fbb.jpg STR60GT Six-Piston Front Calipers -Forged and Weight Optimized for Unsprung Weight Reduction -Stiffest Caliper Available with Patented Strengthening Bridge for improved Pedal Feel & Modulation -Eliminates Pad Taper Wear and Provides Consistent Performance 380mm x 32mm Wide Annulus Aero Rotors STR41 Four-Piston Rear Calipers -Forged and Weight Optimized for Unsprung Weight Reduction -Stiffest Caliper Available with Patented Strengthening Bridge for improved Pedal Feel & Modulation -Eliminates Pad Taper Wear and Provides Consistent Performance 380mm x 32mm Standard Annulus Aero Rotors |
Any particular reason you guys went with Stoptech instead of AP or Alcon? If I didn't already have a BBK on my car, I would certainly consider these, but am also really happy with the AP radi-cal set up.
Originally Posted by fleming23
(Post 1597460866)
I got to check these out today. They are light for how huge they are.
You cant really tell form the picture above but they are vented all the way through around the pistons which I though was a cool (I made a pun) feature. Also, got to check out the car that's going to Nürburgring... looking bad azz. |
Originally Posted by MCK_Z06
(Post 1597462934)
You cant really tell form the picture above but they are vented all the way through around the pistons which I though was a cool (I made a pun) feature. Also, got to check out the car that's going to Nürburgring... looking bad azz. https://cimg2.ibsrv.net/gimg/www.cor...0a3f9e7d89.jpg |
Originally Posted by Dane@LGmotorsports
(Post 1597459022)
Originally Posted by Deity.Motorsports
(Post 1597464805)
Cant wait to see how they perform. Dave at Stoptech showed me pics of these calipers before unveiling at SEMA last year. The pads are 1” thick, durable enough for some 24 hrs racing events! https://cimg1.ibsrv.net/gimg/www.cor...095009d8ed.jpg |
Update!
https://cimg0.ibsrv.net/gimg/www.cor...afb91f4dbd.jpg We have four kits in final inspection/assembly that will be in stock shortly. We will give preferred pricing to these first four purchasers and the next production run will not occur until after we go for a time at Nurburgring in October. Be first, save $ and skip the wait. Or just sit in the middle of the pack and follow the leaders:D Give us a call at 972-429-1963 for more info, or to order |
Knowing you will not quote product prices, which is more expensive, these or the APs you have on the other car, and by how much?
Originally Posted by jim2092
(Post 1597834306)
10-4, I see you recognize one of your customers. lol
(Post 1597460866)
What is the weight difference on this Stoptech kit vs the j57 and j56 Brake’s? |
Originally Posted by Pacembellum
(Post 1598682144)
(Post 1598682337)
I have all the weights written down somewhere. I'll have to go through old notebooks to find them. I remember that the front caliper & bracket was 8.9lbs.
Edit 380x32 Wide Annulus Left: https://www.zeckhausen.com/catalog/p...ducts_id=17054 Right: https://www.zeckhausen.com/catalog/p...ducts_id=17055 These are MSRP; you can often find them for cheaper. |
Originally Posted by X25
(Post 1599407881)
Were you able to find your weight data? I'm guessing the rotors might be a bit heavy due to wide annulus, but it'd definitely be worth it for extra braking capabilities. What pads and replacement rotors does this kit use? If we were to get the kit, it'd be very important to be able to find replacement parts for cheap. The pad is mentioned as 1" thick; is it the same ST60 pad, but just 1" thick? I can also find the 380x32 wide annulus StopTech rotors. Here's hoping these would be what this kit comes with, and nothing custom : )
Edit 380x32 Wide Annulus Left: https://www.zeckhausen.com/catalog/p...ducts_id=17054 Right: https://www.zeckhausen.com/catalog/p...ducts_id=17055 These are MSRP; you can often find them for cheaper. Those are the correct replacement rotors. The pads are actually a brembo endurance pad shape so it's readily available. We ran PFC 7799.13.25.44 front and PFC 0345.11.17.44 rear. |
Those are the most expensive pads I've ever seen!
So, from the part numbers, looks like the rears are 17mm thick; good to know. |
(Post 1599412838)
