GA: C5 97-04 spare parts both new/used/aftermarket/oem ARP, TSP, TPIS, Block, Heads..
As the title states I have a bunch of spare parts lying around that are either off or where for my C5 build. Im in no rush to sell any of the items. All prices are before shipping. For large items like the transmission you will have to organize your own shipping. Some of these parts are new, some are used, some have barely any use. Most parts are oem unless stated otherwise.
AVAILABLE: 1) TSP 7.40 Chromoly pushrod set (10k miles)- $75 2) GM LS2 Lifter Tray set (10k miles)- $20 3)LS7 Lifter Set (10k miles)-$ 150 4) TPIS LS6 Intake Manifold flow matched to 92mm Fast (works with LS2 TB bolt pattern) - $580 5) C5 Corvette Rear Differential 3.42 (Casing is cracked, only selling for parts..internals, covers, sensor) - $180 6) OEM Front Bumper (has two small cracks and spider web cracks in clear, will need a repaint, comes without mesh vent grills) - $250 7) OEM Passenger side Fender (has one small crack as pictured and comes without the emblem) - $300 8) OEM LS1 Oil Pump (works perfect, roughly 100k miles) - $40 9) Miscellaneous head parts (all roughly 100k miles, valves, springs, lifters, bolts, etc.. selling due to heads and cam upgrade) - $200 for all 10) OEM Smog pump lines, brackets etc. (roughly 80k miles, no smog pump included) - $80 11) OEM LS1 5.7 Camshaft (198/208 500/500 lsa 115.5) - $200 12) OEM LS1 Valve Covers and oil cap - $80 13) Convertible/FRC Trunk Glass two outer panels - $60 14) OEM Foglight housing (slightly trimmed for air flow) -$60 15) Traction Control bezel (I do not believe the button works, but the bezel is in good condition) - $40 16) Coolant Recovery Tank (expansion tank/ coolant reservoir) sensor and Cap -$40 17) Granatelli Motorsports Mass Air Flow Sensor (bought it used never installed due to vented hood and tuning) - $140 18) OEM LS1 806 Cylinder Heads (Roughly 100k miles, no cracks, stripped bolts etc.) -$250 19) OEM Foglight housing (slightly trimmed for air flow) -$60 20) Traction Control bezel (I do not believe the button works, but the bezel is in good condition) - $40 21) Coolant Recovery Tank (expansion tank/ coolant reservoir) sensor and Cap -$40 22) Granatelli Motorsports Mass Air Flow Sensor (bought it used never installed due to vented hood and tuning) - $140 23) OEM LS1 806 Cylinder Heads (Roughly 100k miles, no cracks, stripped bolts etc.) -$250 24) LS1 5.7 Coolant Crossover tubes - $80 25) OEM LS1 Valley Cover - $60 26) Complete 10mm Torque tube assembly for 6-speed (Rubber Couplers are have less than 15k miles, I know it needs rebuild i think the bearings or something I forget what) - $200 27) Driver Side Headlight bezel (New updated design) - $20 28) Driver Side VetteNuts Headlight Cover (new no problems) - $120 29) Front License plate holder i.e THIS IS NOT THE FILLER THAT SAYS CORVETTE, but instead is the filler that would allow you to hold and mount a front license plate (New in bag never opened) - $40 30) LS1 Motor Mounts and Diff/Trans mount (50k miles) - $80 SOLD: TSP Torquer V2 Camshaft 112 LSA (10k miles) - $300 If its not crossed out, and price removed then it is still available. No holding parts You can text me at 770-815-Zero81Zero if you want any additional pictures of specific items or if I dont respond here fast enough. Method of payment will be paypal if not local pickup |
Which torque tube? 10MM 12MM?
Thanks for the response!
No current need -- just thought if it was a 12MM in need of service, it would be worth doing over time to have for an eventual upgrade. |
How much for the knee Bolster?? nevemind just say it’s gone already |
still have motor mounts for sale?
Sent PM looking for ebcm assembly
C5 parts for sale
Very small request: Relay #42 from the footwell fuse box. If not worth your time, I understand.
Also, what is a "valley cover"? |
Would you sell and ship the main/upper bell housing? NV 89139
Interested in the front bumper. Can you send a pic. Thx |
Also interest in a passenger fender 2000 corvette
Front plate holder
Interested in plate holder. Could you send a pic? Thanks |
Originally Posted by Daddy o
(Post 1598532503)
Interested in plate holder. Could you send a pic? Thanks https://cimg7.ibsrv.net/gimg/www.cor...1289e92d49.jpg https://cimg5.ibsrv.net/gimg/www.cor...1f857b0787.jpg |
Originally Posted by GradyBaby16
(Post 1598636904)
Bump, will also have a good 5.7 ls1 short block soon, completely bare no accessories
Still have the AIR pump? Would you sell pump only no lines or brackets?
Do you still have the drivers side headlight bezel, and does it come with the plug?
Is the car silver or pewter (I’m asking about the headlight bucket cover)?
Do you still have your traction control part, plastic surround including the button. I know you said the button does not work?
PM sent.
