Big Block Engine Identification - 396?
Hello everyone, I just brought home a motor that I was told was a 396 and I am having a hard time determining what it is/what it came out of - it may be a bit of a Frankenstein engine but your expertise would be appreciated!
Engine Casting # 3855962 Exhaust Manifold # 3880827/3880828 Intake manifold # hard to determine if it is the 3866948 or 3883948 - I will work on cleaning it up and update if it does. The engine pad stamp # T0920EJ |
The 962 block is a 396 used in 65-66 Chevelles, Impalas and in 65 Corvettes. It’s a four bolt main block. On the passenger side of the block is machined pad with numbers stamped into it. Post those numbers. Do not use ANY abrasives on that pad. |
(Post 1597770241)
Chevelle
I believe EJ is a 1966 360hp or 1967 350 hp from Chevelle with MT and AIR (smog) probably a Cali car. Check cast date to tell which.
Originally Posted by Vette5311
(Post 1597770577)
Originally Posted by Christopher McBee
(Post 1597770198)
Engine Casting # 3855962 Exhaust Manifold # 3880827/3880828 Intake manifold # hard to determine if it is the 3866948 or 3883948 - I will work on cleaning it up and update if it does. The engine pad stamp # T0920EJ https://www.chevelles.com/forums/18-...-max-bore.html Good luck... GUSTO |
Originally Posted by GUSTO14
(Post 1597772673)
I believe that this block can also be safely bored to 4.251 and made into a 427 should you feel the need or have some other (re: 427) internals laying around.
(Post 1597772733)
I don't think so. the 65 cast blocks maybe. but this one is for a 66 application. unless it has "fangs" above the timing cover
GUSTO |
