my 72 Vette wiper door closes on wipers at different intervals
!972 Corvette wiper door closes on wipers at different positions. I have to keep trying to park them multiple times to get them close to parking in the full close position but rarely can get them in the perfect spot. Door closes quickly and does not wait until the wipers are fully down. Any suggestions as to the culprit.
Did it just suddenly start acting like that? Any history on you working on that system?
Originally Posted by kansas123
(Post 1597777717)
Originally Posted by DC1972
(Post 1597777340)
Sounds like it might be caused by the wiper door safety switch, which is underneath the passenger side wiper arm near it's pivot point. It tells the wiper door that the arms are parked and it's okay to close.
I was thinking it was probably the safety switch also since it only close on the wiper arms when I turn the wipers off and not any other time. Is the safety switch vacuum controlled or electrical? |
Also, Tex, there is a one-way valve so you don't lose can vacuum when you hit the throttle. Yours is either blown or nonexsistant. Reminds me of school busses when I was a kid. Drivers had to lift off gas to make the vacuum wipers go.
It is defiantly the safety switch under the wiper door, passenger side. It pretty much fell apart once I got to it. Does anyone know if the heater hot water shut off vacuum valve for 77 to 79 is the same as the wiper vacuum safety switch on the 72. they both look identical except the hot water valve is half the price for the one that is made in the USA.
(Post 1597782435)
I was thinking it was probably the safety switch also since it only close on the wiper arms when I turn the wipers off and not any other time. Is the safety switch vacuum controlled or electrical? By the way, does the switch under the steering column work? The pull down knob on the right side of the large round knob controls the vacuum door: if you pull it down (with the car running), the vacuum door should open and stay open. The round knob turns the wipers off (so that you can stop them at the top of the cycle when you need to change the blades). |
(Post 1597786252)
It is a vacuum switch.
By the way, does the switch under the steering column work? The pull down knob on the right side of the large round knob controls the vacuum door: if you pull it down (with the car running), the vacuum door should open and stay open. The round knob turns the wipers off (so that you can stop them at the top of the cycle when you need to change the blades). does the black knob on the left do anything? I have had my hands full rebuilding the front suspension and steering componets. Now that that that is done I have finallyt been able to get it on the road and started on other fixes. |
(Post 1597786890)
Not certain as I have already removed the wiper safety switch. For whatever reason I didn't realize the pull knob on the right moved, I was only aware on the knob to turn off the wipers. Still learning...
Ok that makes perfect sense. I have ordered the vacuum safety switch, will know I a few days if that is the complete fix or not. |
(Post 1597781546)
