Screw size list?
Is there a list out there where screw numbers AND sizes are listed next to various C3 items they secure?
The reason I ask is that I just painted my '73, and now it's time to re-assemble everything back. I've tried using the Ass. manual, and it's a tremendous help in assembly, but when I do the search with the screw's part #, more than half the time I cannot come up with a size description. No doubt I should have bagged each screw with a location description, but too late of course for that. :rolleyes: Perhaps just a reliable screw/bolt website, with GM # with it's size listed, that someone knows. I'm retired, and yeah I've got time to do it by way of fitting what I think will fit, but just how much time IS left, ya know? ;) Just want to do it right. Thanks much. Steve |
no sizes as such,
but i have looked at http://www.corvettefasteners.com/ many times to see what a certain screw is supposed to look like. |
I bought a complete set of fasteners from Ecklers for my 68 convert. It had little plastic ziplock bags of all of the various sizes labeled for what they were used to fasten. I believe they also sell individual bags specific for the parts they are used to fasten.
I bought a screw set for just the interior Ron, but they didn't have the size of the screws printed on the packages. :confused:
Steve |
Look up AMK, they reference GM numbers for the (limited) fasteners that they sell. This has been discussed in the past, you might search if you already hadn’t. Alan71 has posted many photos of various fasteners. Bob |
https://cimg3.ibsrv.net/gimg/www.cor...cb4cee5df1.jpg
FWIW: The Parts and Illustrations Catalogue lists quite a lot of fastener sizes. You can find these in paper or on CD. :thumbs: |
Originally Posted by riverracer au
(Post 1597937573)
no sizes as such,
but i have looked at http://www.corvettefasteners.com/ many times to see what a certain screw is supposed to look like. Thank you sir. Steve |
Originally Posted by boat196
(Post 1597937751)
Look up AMK, they reference GM numbers for the (limited) fasteners that they sell. This has been discussed in the past, you might search if you already hadn’t. Alan71 has posted many photos of various fasteners. Bob Thanks. Steve |
(Post 1597938395)
FWIW: The Parts and Illustrations Catalogue lists quite a lot of fastener sizes. You can fid these in paper or on CD. :thumbs: Thanks. Steve |
It is generally a real PIA to find bolt sizes. It is time consuming the way I have been doing it. I go to the AIM and get the GM part number. I then go to the NCRS forum and search that part number. Most of the time Joe Lucia has posted the size and finish of the bolt.
Good luck, Allen |
You can also get the digital catalog from paragon for c3. In the back they have alot of info on them.
https://cimg4.ibsrv.net/gimg/www.cor...0f7d4acb65.png |
Originally Posted by Cavu2u
(Post 1597937645)
Steve |
Originally Posted by raven1708
(Post 1597941436)
https://cimg4.ibsrv.net/gimg/www.cor...0f7d4acb65.png Thanks for the info. :cheers: Steve |
Originally Posted by ronarndt
(Post 1597942074)
My set did not have sizes either. The bags just said where they were supposed to be used.
Thanks Ron. Steve |
(Post 1597944902)
At least we could match 'em up at the local hardware store.
Thanks Ron. Steve |
(Post 1597949193)
I have lost track of how many times I have spent standing in the fastener section comparing the one size I need to the variety of sizes available to find the right one. Even with the selection I bought from Eckler's I ran out and had to buy more.
I swore I removed the exhausr bezel's tinnerman nuts from my '73 exhaust panel that looked like this. https://cimg7.ibsrv.net/gimg/www.cor...4b9a85b1fa.jpg Instead, I got these.:shrug: https://cimg9.ibsrv.net/gimg/www.cor...3d66558a64.jpg https://cimg5.ibsrv.net/gimg/www.cor...ec2278947a.jpg |
(Post 1597938395)
Very little hardware is actually listed in the "Corvette Parts and Illustration Catalog". All hardware was found in GM Parts Group 8.900, and Group 8.900 is not included in the Corvette Parts book, but instead is only found in the GM "Standard Parts Catalog".
The Standard Parts Catalog is a great resorce. Every nut, bolt, screw, washer, J-clip, cotter pin, etc used by GM, are listed in the Standard Parst Catalog. Unfortunately, it's almost impossible to find a part in it, if all you have is the part number, or it's usage. Since it was intended for use by a dealer's service department, and the dealer's mechanic would already have the piece of hardware that needed to be replaced, all hardware is listed by the type of hardware it was. If you needed a black phosphate, hex head, captive washer bolt, with a pointed end, you went to the section for that type of bolt, and then went down the list of sizes until you found the size you needed, and the part number would be next to the size. It's virtually impossible to find a part by it's part number in the Standard Parts Catalog, unless you know the exact description of the hardware you're looking for. :willy: I have some Standard Parts Catalogs, and refer to them often, but their not the easiest thing to use, if you're not real familiar with GM hardware already. The Paragon hardware chart is about the best simple chart available to the restorer. It is included in the back of all of their catalogs, and they use to have them as a large, poster size wall chart too. They use to give them out at swap meets and in their showroom, but I don't know if they still do. I have one on the wall at the store and another in my home garage, and use them regularly. You might want to call Paragon and see if they still have the wall charts. And if they're all gone, they might be persuaded to print more of them, if enough people call looking for them. :lol: |
Originally Posted by gbvette62
(Post 1597967335)
The Standard Parts Catalog is a great resorce. Every nut, bolt, screw, washer, J-clip, cotter pin, etc used by GM, are listed in the Standard Parst Catalog. Unfortunately, it's almost impossible to find a part in it, if all you have is the part number, or it's usage. Since it was intended for use by a dealer's service department, and the dealer's mechanic would already have the piece of hardware that needed to be replaced, all hardware is listed by the type of hardware it was. If you needed a black phosphate, hex head, captive washer bolt, with a pointed end, you went to the section for that type of bolt, and then went down the list of sizes until you found the size you needed, and the part number would be next to the size. It's virtually impossible to find a part by it's part number in the Standard Parts Catalog, unless you know the exact description of the hardware you're looking for. :willy: I have some Standard Parts Catalogs, and refer to them often, but their not the easiest thing to use, if you're not real familiar with GM hardware already. The Paragon hardware chart is about the best simple chart available to the restorer. It is included in the back of all of their catalogs, and they use to have them as a large, poster size wall chart too. They use to give them out at swap meets and in their showroom, but I don't know if they still do. I have one on the wall at the store and another in my home garage, and use them regularly. You might want to call Paragon and see if they still have the wall charts. And if they're all gone, they might be persuaded to print more of them, if enough people call looking for them. :lol: Steve |
