Battery replacement for C7 2016 corvette stingray
2016 corvette stingray --- any precautions jump starting a dead battery ... Use battery pack? ... another vehicle? Should I connect to charger and slow charge to see if it will hold a charge?
Originally Posted by Bluebart9
(Post 1597960503)
My OEM battery in my 2015 was giving me slow starts after only 3 years , Now I drive this car , it has 37,000 on it so its not sitting in the garage , started to get worried to the point where I was carrying jumper cables just in case . had it tested multiple times , at the dealer as I was hoping warranty would cover it and at Auto Zone and it always came back as the battery was good This weekend at the track , after multiple starts and stops , it almost did not start ……. I was surprised when I looked and the battery and it was only a 550 cold cranking amp battery which is small , I tried putting it on the charger, and it would still start slow , so this weekend I bought a new battery as it was just not worth for me to get stuck So I bought the biggest battery I could get for the Corvette a 760 Cold cranking amps and 930 total …. from Auto Zone …. https://shop.advanceautoparts.com/p/...t+Platinum+AGM For the first time since I own the car I am not worried about it starting … darn thing sounds like a jet engine starting now …. Dave |
Originally Posted by Dcasole
(Post 1597966376)
Blue , you never want top FAST CHARGE a dead battery , I would slow charge it no more than 10 amps … and if the battery is 3 years old , just replace it , if its 4, you are on borrowed time and 5 , just dump it now......
My OEM battery in my 2015 was giving me slow starts after only 3 years , Now I drive this car , it has 37,000 on it so its not sitting in the garage , started to get worried to the point where I was carrying jumper cables just in case . had it tested multiple times , at the dealer as I was hoping warranty would cover it and at Auto Zone and it always came back as the battery was good This weekend at the track , after multiple starts and stops , it almost did not start ……. I was surprised when I looked and the battery and it was only a 550 cold cranking amp battery which is small , I tried putting it on the charger, and it would still start slow , so this weekend I bought a new battery as it was just not worth for me to get stuck So I bought the biggest battery I could get for the Corvette a 760 Cold cracking amps and 930 total …. from Auto Zone …. https://shop.advanceautoparts.com/p/...t+Platinum+AGM For the first time since I own the car I am not worried about it starting … darn thing sounds like a jet engine starting now …. Dave |
Originally Posted by mbaessler
(Post 1597971324)
Dave, your link you provided said they would install it for free when you buy the battery. Knowing that it's not too forward to change the battery. Did they do it for you while you waited?
They have a disclaimer that says they don't do certain cars because they are hard and I think the Corvette might fall into that category , I would call the store that you are going to use as I am sure that the abilities of the staff vary location to location So I did mine myself …… Changing the battery out in a C7 is a lot harder than it looks as you have to take the interior plastic trim pieces on the RT rear side and across the back out of the car in-order for you to get the battery out of the cubby , these pieces were installed before the carpet and some floor panels so it made it difficult to take these off , being in the business I had the tools I needed to do this without disassembling the whole rear of the car . unhooking the rear cargo light and POWER port can be a challenge as there is not a lot of wire to work with The panels just pop on and off but you have to be careful not to break the standoffs that hold the clips in place You then have to carefully fold the carpet back being real careful you don't tear the backing and remove and tie the positive and negative cables out of the way . there is a set of fuses mounted to the battery using the positive cable clamp , the positive cable connects to this fuse panel with a 13 MM bolt , remove the cable first , then remove the assembly off the battery and set aside , Remove the vent tube , take off the hold down bar that is secured by 2 10 MM nuts The original battery does not have handles so you have to use a battery lifting device as there is no way you can get your hands around the battery and lift it , I looped a nylon hold down strap around the battery and used this for lifting Once out, transfer the little VENT TUBE over to the new battery , the new battery had handles so it dropped right back in , then I just reversed the assembly process , hooked up the wires and was set to go , everything goes back together nicely and you can never tell that I had the car apart So , if you have a good mechanical ability and some tools ( 1/4 ratchet and extension , 10 MM and a 13 MM socket , panel tool or large screwdriver , something you can use to loop around the battery to lift it out ) it will take about an hour , if not …. I would highly recommend paying the dealer to do the job , just make sure you ask for a bigger battery than the stock one as it is hardly up to the task of starting and powering the car Please feel free to PM me or email me thru the forum if you have more questions as I would be glad to walk you thru it Dave |
(Post 1597971873)
mbaessler, I have had them install batteries in a few of my cars in the past just because I did not want to get dirty and they don't charge for it , I just give the guy a tip but I don't think I would let them put in my Corvette battery
Be sure the person that installs it is familiar with the procedure Dave nicely captured above. Otherwise a rookie while tear your trunk carpet.
I have a 15 too and I used this one https://www.4wd.com//p/odyssey-batte.../R-FBBX-48-720. I installed it myself but it's a lot better than the factory one. I was getting some codes that didn't make sense and after the battery change have not had any more codes. With the electronics on these cars it pays to have a good battery.
Originally Posted by badhabit_wb
(Post 1597977867)
The Odyssey 2 year is full replacement not prorated, unless they've changed recently. I've bought both and have had better service from odyssey than any other battery I've used, agm or otherwise.
Originally Posted by Mr. Wonderful
(Post 1597978324)
This battery shows only 2 year free replacement while the Advance Auto version above is a full 3 years. I would probably choose that one with the additional year of protection.
This was the best money I have spent in a long time as I no longer worry about going out to the car and having it not start ...or watching my battery guage spike to 15.1 Still cant believe that GM puts a 500 amp battery in a Corvette, my Tauruis has a bigger battery lol lol Dave |
(Post 1597978364)
the platuim is also a 3 year full replacement plus I got a 20.00 rebate :thumbs: Dave |
(Post 1597978453)
that's cool !!
Need to say thank you whoever posted on how to remove the C7 battery. I was just charged $550 for a new one ... outrageous! |
any idea how much dealer charges to swap it?
Originally Posted by The T-man
(Post 1598440660)
Labor: 65.00 Battery: 124.95 (42 month battery 48PG) Misc fee: 7.15 Tax: 10.86 |
550 here in San Diego at Jimmie Johnson Chevy... |
How do you prevent the radio from loosing the VIN information? Can you plug in a tender while you change the battery and keep the system from loosing the programming?
I haven't heard of this happening on the C7. Guys are unplugging their batteries all the time while diagnosing problems.
I didn't have any problem with mine when I switched the battery.
