New C6 Z06 owner in NJ
Just picked up my first corvette this being a low mileage 2013 C6 Z06. Completely stock. Car sounds amazing and feels great. I have an S2000 as well that I track hard and it's nice to feel some torque lol. Basic pics below. I plan on changing all the fluids (oil, trans, diff, clutch) and maybe next year look into a new set of rims/sticker tires than the original tires. For now the goal is just to enjoy on the street maybe some autocrosses, drag strips. I would love to track this car but still have a dedicated s2k which is a blast, maybe someday.
Any other recommendations to do? https://cimg2.ibsrv.net/gimg/www.cor...21addd7f75.jpg https://cimg3.ibsrv.net/gimg/www.cor...6b412ce6c3.jpg https://cimg5.ibsrv.net/gimg/www.cor...dc6f3886fd.jpg |
Beautiful Z. Rarely see one in white, and the polished Spyders compliment it very well. Congratulations, and welcome. :cheers:
Get the heads checked out asap. Most replace the factory heads with an aftermarket setup while they've got everything apart. HCIE Z06's are easily capable of 600rwp. Good luck, and enjoy. :thumbs: |
Originally Posted by TorchRedLS6
(Post 1597972055)
Get the heads checked out asap. Most replace the factory heads with an aftermarket setup while they've got everything apart. HCIE Z06's are easily capable of 600rwp. Good luck, and enjoy. :thumbs: I don't plan on doing much power modification just reliability since NASA, SCCA restrict those things for entry level classes in racing/autocross/time attack. Would just work on suspension/tire/aero setup. |
Congrats! South Jersey here..just picked up my 08 Z06 in June.
My god man! A white ZO6!! Well played sir....well played. :flag: |
Originally Posted by xene106
(Post 1597971913)
Another S2000 and Z06 owner! there is a theme here. Honda gave up a lot of repeat customers by not coming out with a second generation. I had it 10 years and while not tired of it at all - loved it - wanted to try something new. As 73DBG mentioned there is a S2K/Z06 thread here. I co-owned both a few months, and my son bought the S2000 - that was the plan - once he got situated with a job post college and an apartment with a parking garage, he would buy it and I'd get something else.
https://cimg0.ibsrv.net/gimg/www.cor...6121ae913a.jpg |
Looks good! How many miles on it? |
HEADS HEADS HEADS, if your from Jersey call up Chris from ECS. They will take care of you. Great shop! Sweet Ride!
Originally Posted by MTPZ06
(Post 1597973982)
Originally Posted by C6Z06Silverbullet
(Post 1597975154)
(Post 1597975184)
Thanks for tip. I was planning on doing AHP but may take a look at them if reputable and quality machine work. They are local for me so that would be convenient. What work did Chris do for you on your corvette?
Welcome to the forum. Upgrading to a ZR1 rear spoiler would be a nice touch.
(Post 1597975184)
Being a 2013, and low miles also keep an eye on the rods as that is a major issue. Get the Ti levels checked.
Great car... Welcome!
(Post 1597975184)
Originally Posted by venemous1
(Post 1597978937)
Prior owner on my white C6Z had ECS do the head cam work to my car before I got it and the failed to put the C5R timing chain in it when doing the install. Prior owner paid for it and they stuck the factory timing chain in it and cost me $1000's to repair recently when it broke on me. I wouldn't trust them to change a lug nut on my car after discovering this.
Originally Posted by Unreal
(Post 1597977537)
Car has like 5300 miles and runs and sounds smooth. The only thing is a very mild engine ticking noise with revving but I was reading this is normal for this engine since its an older push-rod style. Also could be an issue with internal transfer tube in oil tank bouncing around, but I have to pinpoint the noise with my mechanic stethoscope. I am use to minimal valve train noise of DOHC engines like Hondas. Still have a lot more reading to do. |
(Post 1597980062)
Yea this is one thing that is unfortunate. I was reading that most cars with the bad bearings due to improper coating on the connecting rods should of failed by now. The examples I was reading about failed at like 2000 to 3000 miles. It only affected a very small number of the 2013s and was corrected for the majority. I still got a 3 month powertrain warranty on the car so plan on driving a lot to get another 2-3k miles on the motor to check the oil for analysis. The oil was just changed prior to buying otherwise I would check right now with quick change.
