A8 C7 Z06 owners-how do you perform a burnout
Sorry I searched and couldn't find anything. I was wondering how you A8 Z06 owners performed your burnout. Did you do it in Manual mode or in Drive?
TIA! |
Originally Posted by avtarv
(Post 1598053617)
TIA! Using this driving mode seems to be the only real way of consistently being able to do a burnout because with any other mode what I found is that while it's possible to get the rear tires spinning, the minute the rear end starts to swing to the left or right the PCM cuts power. Here's a pic from a couple years ago: https://cimg4.ibsrv.net/gimg/www.cor...d606b8ade3.jpg |
What Christopher mentioned is correct. The only thing I will add is I start in M1, When the rears start spinning and rpms go up I shift to M2 and complete the burnout. Lighten up on the brake and continue spinning a few feet toward the staging lane. Put the selector back in Auto and you're good for a 10 second pass.
Originally Posted by 383vett
(Post 1598054861)
