Hooker shorty headers install
1 Attachment(s)
Figure I share my shorty header install in case someone finds it useful...
I've read several threads on the subject so I'm aware of the controversy. People are correct though, it is a minimal power improvement for the cost. Reason I went with them is cause I'm an idiot and want to avoid emissions test issues. I had ESP, a local shop, install the Hooker Blackheart Shorty headers. ESP said there were no issues with the install so, fitment was good. ESP did an awesome job BTW. Cost was 1400 for headers + install + 2 dyno runs. I paid 750 for the headers. Didn't notice any sound change but dyno did report a power improvement. Pulls were done on a Mustang Dyno. Between weather corrected and non-corrected, it shows something like 4 to 20 HP increase and 50-60 lb-ft torque. It feels like it pulls harder in the power band but hard to really tell since it already has a lot of power that I can't use on the public roads. Haven't taken it to the track yet but won't be till next year; after a long winter :( Here's a complete list of mods... 2016 Stingray Z51, stock bottom end, Magnuson Heartbeat with 84mm pulley (3mm down from stock; 87mm) at 8-9 PSI, GM secondary radiator, Katech Ported TB, Alky Control kit, Single M15 nozzle, running 70/30 Meth/water mix. 93 Octane Gas. BMS Air Filter, and new OEM/ACDelco plugs @.037 gap. The boost level didn't appear to change; still getting same 8-9 PSI. Actually peaks about 9.5 PSI. Since the dyno runs looked good, trims looked almost the same, fuel was good (12.2 AFR), I didn't do anything with the tune. I included the last dyno pull log for the technical/tuning inclined... Here are all the dyno numbers and pics below.... Baseline Before headers (Very cool out, 45*F but dry)... 553/492 rwHP/Tq 544/484 rwHP/Tq WCF (WCF are lower because it was a cold day; was told anyway). With Headers and new plugs (60*F, warmer but rainy/humid)... 557/534 573/549 WCF (Weather Correction Factor) Performance increase.... 4/42 HP/Tq 20/65 (WCF) I'm guessing it should do about 600-625 on a DynoJet right? Which would be slightly better than the average Z06 so....Mission accomplished :) Anywhoo...Overall I'm happy with them so far... https://cimg7.ibsrv.net/gimg/www.cor...7bc535cddc.png https://cimg8.ibsrv.net/gimg/www.cor...e962f96a70.png https://cimg9.ibsrv.net/gimg/www.cor...6f7a1d2a2e.jpg https://cimg0.ibsrv.net/gimg/www.cor...cd652e1b8e.jpg Anyone else try these out? Got better/worse results? |
Im surprised it didnt changed the sounds, even though you kept your cats, i would expect a more meaner sounds!!??
Think I heard just a tiny bit of difference during idle but I run the exhaust in track mode so don't really hear any diff.
Pj |
Not bad. They pair up great with a cat delete too.
Originally Posted by pj-c7
(Post 1598284779)
I've read several threads on the subject so I'm aware of the controversy. People are correct though, it is a minimal power improvement for the cost. Reason I went with them is cause I'm an idiot and want to avoid emissions test issues. I had ESP, a local shop, install the Hooker Blackheart Shorty headers. ESP said there were no issues with the install so, fitment was good. ESP did an awesome job BTW. Cost was 1400 for headers + install + 2 dyno runs. I paid 750 for the headers. Didn't notice any sound change but dyno did report a power improvement. Pulls were done on a Mustang Dyno. Between weather corrected and non-corrected, it shows something like 4 to 20 HP increase and 50-60 lb-ft torque. It feels like it pulls harder in the power band but hard to really tell since it already has a lot of power that I can't use on the public roads. Haven't taken it to the track yet but won't be till next year; after a long winter :( Here's a complete list of mods... 2016 Stingray Z51, stock bottom end, Magnuson Heartbeat with 84mm pulley (3mm down from stock; 87mm) at 8-9 PSI, GM secondary radiator, Katech Ported TB, Alky Control kit, Single M15 nozzle, running 70/30 Meth/water mix. 93 Octane Gas. BMS Air Filter, and new OEM/ACDelco plugs @.037 gap. The boost level didn't appear to change; still getting same 8-9 PSI. Actually peaks about 9.5 PSI. Since the dyno runs looked good, trims looked almost the same, fuel was good (12.2 AFR), I didn't do anything with the tune. I included the last dyno pull log for the technical/tuning inclined... Here are all the dyno numbers and pics below.... Baseline Before headers (Very cool out, 45*F but dry)... 553/492 rwHP/Tq 544/484 rwHP/Tq WCF (WCF are lower because it was a cold day; was told anyway). With Headers and new plugs (60*F, warmer but rainy/humid)... 557/534 573/549 WCF (Weather Correction Factor) Performance increase.... 4/42 HP/Tq 20/65 (WCF) I'm guessing it should do about 600-625 on a DynoJet right? Which would be slightly better than the average Z06 so....Mission accomplished :) Anywhoo...Overall I'm happy with them so far... https://cimg7.ibsrv.net/gimg/www.cor...7bc535cddc.png https://cimg8.ibsrv.net/gimg/www.cor...e962f96a70.png https://cimg9.ibsrv.net/gimg/www.cor...6f7a1d2a2e.jpg https://cimg0.ibsrv.net/gimg/www.cor...cd652e1b8e.jpg Anyone else try these out? Got better/worse results? I didn't notice any difference in sound or power but I didn't really expect to on the street. I did it to lose the 22 lbs at the front and that mission is accomplished. I put the DEI sleeves over the wires but I'm not sure they're necessary. I got the titanium cerakote and the titanium sleeves so it all looks the same. One thing for sure I'd recommend is the ARP studs. They are money well spent. They also make it much easier to hang the headers if you're alone. While I had everything out I also put in a Tick performance clutch slave bleeder. It's a really tight fit but with everything out of the way it can be done with the clutch and engine in the car. Then it's easy to bleed the clutch. |
