LMR breather Z51 A&A
Does anyone have any pictures of their breather install with an A&A blower, I'm having trouble figuring out the two 6-an lines instructions say the 4th port on the breather goes to the sump, but what about the 3rd ? Is this capped ? I've seen different installs just seeking advice.
Thank you in advance ! |
Originally Posted by C7J
(Post 1598426837)
Thank you Robert ! Do you have a link to the MMS catch can you're talking about ?
(Post 1598426837)
Makes sense.
So after disconnecting the line from the blow off valve, going to the valley cover( below the manifold), do I just have the blow off valve going to the manifold. Right now it goes to the valley and manifold. -Thanks |
(Post 1598436973)
Makes sense.
So after disconnecting the line from the blow off valve, going to the valley cover( below the manifold), do I just have the blow off valve going to the manifold. Right now it goes to the valley and manifold. -Thanks Here are the instructions buddy. This should help! https://www.corvetteforum.com/forums...tructions.html |
ttt
www.mightmousesolutions.com David is a vendor in here also great guy to talk with & he is more then willing to help. He also races what he makes has one hell c7 turbo car.. Robert
