What rpm are you at in top gear at 90mph?
I am at like only 1700 rpm on the A8 in Sport mode. Truly nuts and wondering where everyone else is at.
My car is heavily modified. But this seems to indicate I could do well over 200 mph.:thumbs: |
Originally Posted by chevyfanatic
(Post 1598473782)
My car is heavily modified. But this seems to indicate I could do well over 200 mph.:thumbs: 7th and 8th are for fuel economy and decreased emissions. If you have enough power, you might be able to pull 214 mph in 6th, if your rpm limit is still set at 6500 and your torque converter is locked. Shift to 7th, and you will probably slow down because of the torque reduction to the rear wheels with the higher gear. |
M7 2016 at 2000 rpms 100 mph 7th gear |
C7 Z06 M7 speed vs gears (aero 3, aero 1 top speed 9 mph faster at 195 mph)
Code:
1st 2.29 = 66 mph @ 6500 rpm |
(Post 1598473782)
Originally Posted by Higgs Boson
(Post 1598479388)
the only mod that is going to change your cruising RPMs is tire height. if everyone is running stock(ish) height tires then everyone runs the same RPM at a given speed.
Now i am around 800 whp vs 560 whp stock. I never did check this when stock so not sure ? |
i am HP Tuned so dont think my RPM is that low. My TCM is heavily tuned to. My car JUMPS FORWARD when I shift the A8 manually ! :thumbs:
(Post 1598484757)
so the more power you develop wont lower your RPM. only TIRES ? Its all TIRES ? What about gearing ?
(Post 1598484757)
Now i am around 800 whp vs 560 whp stock. I never did check this when stock so not sure ? If you have stock tire sizes and gearing, with 800rwhp, you're just going to get to the top speed much faster than a 560rwhp, obviously. |
(Post 1598484757)
