Unlikely base MEC using “upgraded LT1”
Does anyone else find the reports of the base model C8 getting an upgraded version of the Lt1 with an estimated 500-520hp highly unlikely. What about the Cadillac derived 4.2l blackwing? Compact design. Built in Bowling Green. Cadillac killing the car it was designed for. 550hp and oh yeah, a reported 500hp detuned version. Sound like that’s your base and GT power plant to me. Why not showcase your latest tech in the most important car release in decades.? |
The CAD drawings of the C8 had it with an LT engine. I think it would make the perfect base engine. Good solid all round engine with out the complexity and high service costs of a DOHC engine. Then you could have the DOHC TT in the optional versions for those that want that. |
I would much prefer a NA motor over something with turbos. CAFE will force the smaller turbo motors but if they can sneak in a few more years of large CI NA motors it would be great. |
No interest for a truck motor in an ME car. |
who has time to create these BULLSHIT accounts to post obvious troll threads...
I still believe the base engine will be an enhanced LT1 (LT2) with port and direct injection delivering a minimum of 500 HP.
Originally Posted by HooosierDaddy
(Post 1598545095)
Originally Posted by ConcernedCitizen
(Post 1598544441)
Does anyone else find the reports of the base model C8 getting an upgraded version of the Lt1 with an estimated 500-520hp highly unlikely. an LT based engine is the lowest cost route to useful HP levels. What about the Cadillac derived 4.2l blackwing? Compact design. Built in Bowling Green. Cadillac killing the car it was designed for. 550hp and oh yeah, a reported 500hp detuned version. Sound like that’s your base and GT power plant to me. Why not showcase your latest tech in the most important car release in decades.? |
(Post 1598545095)
Originally Posted by MitchAlsup
(Post 1598546026)
Z51 engine. Cost. As far as cost to the consumer, how much do you think new dohc 4.2 would add to the price over the Lt1? I say not much as compared to the total price of the new platform. |
Originally Posted by Dominic Sorresso
(Post 1598545082)
(Post 1598546237)
I would think return on investment would far outweigh “cost” as far as GM is concerned.. The Lt1 r&d and production has realized an incredible return for GM, while the “blackwing” is left to languish without a platform or in a limited production model ie c8 GT. That doesn’t sound like GM to me. As far as cost to the consumer, how much do you think new dohc 4.2 would add to the price over the Lt1? I say not much as compared to the total price of the new platform. C6 LS3 base engine 430 HP $7050 C6 Z06 LS7 engine 505 HP $12,169 C7 ZR1 LT5 engine 755 HP $17,915. |
(Post 1598546237)
I would think return on investment would far outweigh “cost” as far as GM is concerned.. The Lt1 r&d and production has realized an incredible return for GM, while the “blackwing” is left to languish without a platform or in a limited production model ie c8 GT. That doesn’t sound like GM to me. As far as cost to the consumer, how much do you think new dohc 4.2 would add to the price over the Lt1? I say not much as compared to the total price of the new platform. b) A new DOHC 4-ish litre motor has 6X the camshaft turning mechanism, 4X the number of cams, 2X the number of valves, springs, tappets,.... a NEW LT1 is $9,700 from JEGS right now a NEW DOHC would be somewhere in the $14,000 range Not "that much" but enough to worry the accountants....... |
The upcoming ME will have, year one and probably after that , a LT1 derived, but enhanced motor. The LT1 started to be designed about eight years ago, appeared in GM trucks six years ago, an eternity in terms of motor developments. The LT2 (for lack of a better code) will be an LT1 with major developments such as the four major ones debuted in the brand new 4 cyclinder GM truck motor, though some of the components of that motor will not be in the LT2, e.g., the turbo. Thanks to JerriVette for finding this video: Here then are some of those potential C8 motor enhancements coming from that new GM truck motor. 1) Electric water pump, with varying amounts of flow based on need, not related strictly to RPM; 2) Advance engine heat management — both for quicker, better fuel and emissions measures on start up, but also for long term motor longevity and power capabilities; 3) Sliding or “axial” camshaft, giving the best variability for both power and economy, not being, as most previous engines are a compromise camshaft needing to balance the two competing needs. Also near infinite adjustability of valve lift. 4) Transitioning from previous two stage/two step oil pumps to a continuously variable output one — for better engine efficiency. With these enhancement we can easily see the ME’s LT2 approaching or exceeding 500 HP, and a roughly similar amount of torque. |
Originally Posted by elegant
(Post 1598549132)
The upcoming ME will have, year one and probably after that , a LT1 derived, but enhanced motor. The LT1 started to be designed about eight years ago, appeared in GM trucks six years ago, an eternity in terms of motor developments. The LT2 (for lack of a better code) will be an LT1 with major developments such as the four major ones debuted in the brand new 4 cyclinder GM truck motor, though some of the components of that motor will not be in the LT2, e.g., the turbo. Thanks to JerriVette for finding this video: https://youtu.be/9w3HItRrbI4 Here then are some of those potential C8 motor enhancements coming from that new GM truck motor. 1) Electric water pump, with varying amounts of flow based on need, not related strictly to RPM; 2) Advance engine heat management — both for quicker, better fuel and emissions measures on start up, but also for long term motor longevity and power capabilities; 3) Sliding or “axial” camshaft, giving the best variability for both power and economy, not being, as most previous engines are a compromise camshaft needing to balance the two competing needs. Also near infinite adjustability of valve lift. 4) Transitioning from previous two stage/two step oil pumps to a continuously variable output one — for better engine efficiency. With these enhancement we can easily see the ME’s LT2 approaching or exceeding 500 HP, and a roughly similar amount of torque. Alfa engines of the 80s. Technology dates back to the 20s. An Italian engineer invented the DCT for armored military vehicles in the 30s so that they would not get stuck in the mud. Ain't nothing new. |
Originally Posted by NY09C6
(Post 1598547240)
what does this even mean? If the ME uses a small block Chevy motor that started life in 1955, it is going to have a serious marketing problem. If it uses a twin turbo hot V DOHC that was just developed and produced this year, Corvette will not be seen as old tech 20th century engineering. The Blackwing will be more powerful that the LT1 and likely more fuel efficient as well. Going old school on the motor makes no sense for a brand new Corvette. |
Originally Posted by PCMIII
(Post 1598558437)
It means the 6.2L is used in the Silverado pick-up truck.
(Post 1598558437)
A DOHC engine would be a cool factor for when you pop the engine cover or to hear it reving out as you go down the road (if Chevy will allow it the high revs). But for me I would much prefer the reliability, lower service costs, better packaging, and equal HP of the LT engine. |
I use my sports cars as daily drivers. I love the idea of a lt1 derived motor for the c8. replacement parts are inexpensive and durability over the life of the engine is world class. go replace a german engine in a german sports car. Good luck. i fully expect a 10 percent increase utilizing the technologies that gm recently released in its 2.7 turbo four truck motor. gm was able to create a 30 percent increase in hp from the 2.4 turbo four 238 hp motor in the cadillac xt4 to a full 310 hp in the 2.7 liter tirbo four... remember the c5 to c6 gm was able to find 50 hp and in the third year of the c6 able to add an additional 36 hp in the ls3 for a total naturally aspirated v8 to gain 86 hp from the 350 hp ls1 in 2004 to 2008 c6s 436 hp powerplant. I believe 500 hp or 40 more than todays lt1 is doable as is 60 hp... think positive and wait for the release... as far as the twin turbo v8...doubling the 2.7 turbo four to 5.4 or 5.5 liters does make some economic semse....same bore, same stroke..blah blah blah...we should see an easy620 hp from the turbo v8... we are all just shooting the breeze...but where I sit...i like inexpensive ohv compact power durable engines for my daily driver sports cars that i plan toput over 100k miles on... i especially lime the fact that maintaince cinsists mostly of changing the oil ever 7k miles or so...changing the spark plugs and wires at 50k miles and not much more... i listen to maintaince and repair costs on using a finely engineered porsche engine to 100k and I cringe... this video makes a crazy bleed on cashflow for an porsche motor... f that..lol Matt's Safari 911 Engine Needs a Rebuild - Here's What's Wrong (And How ... german craftmanship wtf? |
The current LT motor has nothing in common with a 1955 small block. It also not a truck engine as the torque profile of a truck engine is completely different from the Corvette LT engine. But if if someone wants a more complex dohc engine, that costs more, weights more, has a higher center of gravity, will be less reliable, more susceptible to heat soak, has turbo lag and more expensive to maintain/repair/modify so they can save a few cents at the pump, well... they are special, more power to them.
(Post 1598558437)
