1970 LT1 power steering pulley
Wanting to buy a 1970 corvette LT1 power steering pulley.
I didn't think you could get a 70 LT-1 with power steering ...
I didn’t think P/S was available in ‘70 either. I would try the L46 pulley. I do not know if that is different from the L48 setup. |
PS was NOT a option on 1970 LT-1'S. They had a 6 QT oil pan that would not let the cylinder to clear it. Later GM went to a 5QT pan that would in 71.
Power Steering was an option on 1970 LT1s after they changed the oil pan to a 5 quart. The engine suffix changed to CTK i believe.
Kind Regards, Bill |
Bill is correct as early 70 LT1 did have the power steering option how ever it is up to the owner to prove it was factory installed.
However I have a single grooved pulley that is the same configuration as in the Judging manual. I am not up to par on small blocks just Big block stuff, But is there a stamped number on the 70 Lt1 pulley and if any one knows please post the part number Thanks, grant |
The car has to be built after April or May.
Correct. I have an original numbers match with power steering.
Ps
Originally Posted by 1974ta
(Post 1598631787)
