3D models
Hello from Finland :)
First time to write in here... Doesn't know is this correct place for this my question... So, my project is LS swap to -84 C4 (LQ9 with LS3 heads + 4L65E etc.) My problem is that I work a lot with Autodesk Inventor and of course I would like to make nice plan, all needed parts (engine/transmission supports, accessory supports...) ready before I get new engine or take old away. And for that I have tried to found 3D models for components. Engine model I already have (LS3), but haven't found transmission or any other C5 Corvette.. Chevy parts what going to use. (files should be .step, iges etc) Does anybody knows, can those be found somewhere? For engine room, transmission tunnel... I will make 3D scanning, so it would be nice to do everything ready on screen.. then doesn't have any big problems what you don't know or already clarified those problems... ;) And when it's done, I think, no problem to share models to other users here ;) - Vesa |
Are you going to convert to C5 drive train or stay with C4 layout?
I think a FSM for your '84 C4 as well as one for a C5 might have the data you desire. |
I'm going to use C4 drive terrain. And FSM?
FSM - Factory Service Manual
That's not what I'm looking, I try to found 3D models, so that I can install everything on screen, model all brackets etc, so can manufacture needed parts ready before even have new engine/transmission...
Engine I did found... nothing else :( https://cimg9.ibsrv.net/gimg/www.cor...2394125fbb.jpg 3D model from LS3
Originally Posted by cdm747
(Post 1598809891)
There would be no original 3D models that would work in your system from a C4. Even in 96, true 3D modeling was very rarely used. in 84, you would have had wire frame 3D designs. Unless someone is scanning and converting old parts, this is probably a unicorn hunt.
Originally Posted by KyleF
(Post 1598811881)
And now I'm asking models for LS3 + 4L65E + LS3 Corvette parts, those are not so old. And as did write, I'm going to make scanning for car ;) |
You're lucky you have the engine model. I've never seen a 3D model of a C4 engine bay yet and I have been looking for a long time. Turbosquid has C4 models but the engines are not detailed ... also you would have to do some sort of shape-capture from the 3D files to import into Inventor.
https://www.turbosquid.com/3d-models...e-sport/599783 |
These 2D marketing drawings are all I've ever found.
https://cimg9.ibsrv.net/gimg/www.cor...c49f333aa7.gif https://cimg0.ibsrv.net/gimg/www.cor...d88c408c6d.gif https://cimg3.ibsrv.net/gimg/www.cor...acbe7acee8.jpg https://cimg7.ibsrv.net/gimg/www.cor...59bc482df9.jpg |
1986 convertible at Flat Pyramid
L98 turbocharged engine model
Have you looked through grabcad.com?
I know they have a 700R4. |
Originally Posted by belairbrian
(Post 1598825890)
I know they have a 700R4. https://cimg2.ibsrv.net/gimg/www.cor...e184947188.jpg https://grabcad.com/library/ls3-t56-...smission-model |
Yes, from grabcad I did found that LS3 model, but no luck with transmissions :(
4L65E is coming, so should like to get model for that and for TH700r4. And models should be quite accurate, to see how there is free space on tunnel and how support will fit... |
Originally Posted by Veeku
(Post 1598828851)
87 Bob has done this conversion. You might message him asking what parts you need.
Very interested in finding these models too.
