Ported LS7 heads help needed
https://cimg1.ibsrv.net/gimg/www.cor...07b8a4ebd.jpeg https://cimg9.ibsrv.net/gimg/www.cor...3897de74d.jpeg https://cimg0.ibsrv.net/gimg/www.cor...81b8b2820.jpeg I purchased these LS7 heads used and was told they came from Lingenfelter. After talking to Linginfelter it appears they didn’t come from them. I am happy with the heads as the guides are tight and they are CNC ported but was wondering if anyone might be able to identify who might have done the work. The only identifying markings that I see is both heads have the number “26062” hand scribed on the 1st intake runner. |
I have lingenfelter heads and they actually scribe a number on the exhaust side of the head that identifies their work. Im not sure where they came from but runner looks pretty clean
To me, it doesn't look like a CNC machining pattern. It appears to be a hand porting job. I honestly think you're out of luck having someone identifying the heads by looking at one intake port. The numbers "may" help.
Originally Posted by ~STOLEN~
(Post 1598831084)
Lingenfelter uses OEM iron guides. You have bronze. That rules them out anyway.
Originally Posted by Undy
(Post 1598833610)
(Post 1598834429)
this is true also^^^^^ mine are NOT smooth like that (you can see all the cnc marks) ill post a pic of mine, those are a hand blend for sure (but look great) but being they are "fixed" its still not a bad idea to replace the guides with them being a relatively cheap part |
Check with TSP. Looks like could be TSP 265 program heads.
https://cimg1.ibsrv.net/gimg/www.cor...588b5109d.jpeg
(Post 1598834429)
Originally Posted by Vwracermc
(Post 1598839390)
Here is a closer look at the tooling marks and I believe they are cnc. |
CNC, someone went in with a tootsie roll and tried to get rid of the tool marks. If the guides check out run em
(Post 1598840495)
Looks like some clean porting, I'd run em. You might have better luck tracking through previous owners of them.
You should know stock Ti intakes and bronze guides are not a good combination.:cheers:
Originally Posted by Dan_the_C5_Man
(Post 1598845789)
Tsp was able to look up what was done to my heads by me giving them the previous owners name. My heads also didn’t have any markings, just numbers.
Originally Posted by HouseS2k
(Post 1598849748)
CHE mag bronze guides have no issues with the oem valves.
(Post 1598851099)
That's not Katech's position, and they know a thing or two about it.. :cheers:
(Post 1598851692)
Thats funny because they require bronze with their moly coated Ti valves. Moly is the superior coating but the factory CRN is very good also. A few cylinder head companies use bronze with factory valves. WCCH and Advance Induction just to name 2.
It's a domino affect; one component change impacts another. And just because a shop does something doesn't make it right - GM is a Billion dollar company, and look what a mess they managed to create. Never trust anyone implicitly, try to do your own research and then come to a conclusion. :cheers: |
(Post 1598853800)
The original factory CrN coating is abrasive, which is why Katech pushes the use of Moly coated stems, because the head vendor they use, WCCH (yes, NOW Katech offers in-house services, but that only started last year) didn't have access to PM guides that hold up better to the rough coating...
It's a domino affect; one component change impacts another. And just because a shop does something doesn't make it right - GM is a Billion dollar company, and look what a mess they managed to create. Never trust anyone implicitly, try to do you own research and then come to a conclusion. :cheers: |
