C5 Custom Wheel & Tire Database: please fill in your info
A C5 Custom Wheel & Tire Database has been needed on this site, since these cars were built. If your C5 has a custom wheel and tire combination, please add their specs into this database. Feel free to Copy & Paste the information parameters, in this first post. In order to keep the database manageable, I would ask that you please limit your photos, to a Maximum of Four, as this database is for custom wheel & tire information, not intended to be a personal showcase for your car.
Also, this thread is intended as a database, not a question & answer forum. If you have specific questions about any of the custom setups posted here, it would be appreciated if you would ask your questions in the main forum below or PM the member directly, and not in this thread. NOTICE: Please note, if your C5 has the original equipment or replica wheels, it is requested you do not post in this database, for obvious reasons. Thank You ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Wheel Make: Wheel Model: Front Wheel Size: Front Offset or Backspace: Rear Wheel Size: Rear Offset or Backspace: Front Tire Size: Rear Tire Size: Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: Problems or Issues, such as clearance/rubbing problems: Misc.Comments: |
Wheel Make: CCW
Wheel Model: SP500 Front Size: 18x9.5 Front Offset or Backspace: +48 Rear Size: 19x11 Rear Offset or Backspace: +54 Front Tire Size: 265/35/18 Hankook Rear Tire Size: 325/30/19 Hankook Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: lowered on aftermarket bolts Problems or Issues, such as clearance/rubbing problems: none at this time. note: these CCW's will clear C6Z brakes Using 25mm hubcentric spacers behind the rear wheels until they can be widened https://i.ibb.co/y5BV1fQ/Capture46.jpg https://i.ibb.co/3S5pt23/Capture44.jpg |
Wheel Make: OZ
Wheel Model: Superlegger III Front Size: 18x9.5 Front Offset or Backspace: +57mm Rear Size: 19x11 Rear Offset or Backspace: +65mm Front Tire Size: 265/35/18 Michelin PS2 Rear Tire Size: 315/30/19 Michelin Pilot Sport Cup 2 Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: Lowered on stock bolts. Problems or Issues, such as clearance/rubbing problems: none at this time Russ Kemp |
Wheel Make: FIKSE
Wheel Model: Profil 13 Front Size: 17x9.5” Front Offset or Backspace: +44mm Rear Size: 18x10.5” Rear Offset or Backspace: +48mm Front Tire Size: 265/40R17 Rear Tire Size: 305/35R18 Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: Z51 Suspension, Bilstein Sport/B8, Lowered 2”. C6 front bolts all the way down, 6.5” extended rear bolts. Problems or Issues, such as clearance/rubbing problems: None at all https://cimg6.ibsrv.net/gimg/www.cor...d034de086.jpeg https://cimg2.ibsrv.net/gimg/www.cor...6c7e0d86e.jpeg |
Wheel Make: CCW
Wheel Model: SP200 Front Size: 20x10 2" lip Front Offset or Backspace: +64mm or 8" Rear Size: 20x11 2.375" lip narrowed to a 10.5" Rear Offset or Backspace: +69mm or 8.700 is now +62mm or 8.200 Front Tire Size: 295/25/20 Nitto Invo Rear Tire Size: 305/25/20 Nitto Invo Suspension mods: LG Drop Spindles, BC Racing DS Coilovers 400 & 550 spring rates, AMT Camber Kit Problems or Issues : Possibly some minor front bumpsteer, still testing & making adjustments. Misc.Comments: 2.5" & 2.75" lower than stock, absolutely love the ride height, ride quality & handling. https://cimg2.ibsrv.net/gimg/www.cor...1d34d3a75f.jpg https://cimg4.ibsrv.net/gimg/www.cor...68632b1eeb.jpg https://cimg9.ibsrv.net/gimg/www.cor...0afa110040.jpg https://cimg7.ibsrv.net/gimg/www.cor...ce84c4b3c8.jpg https://cimg2.ibsrv.net/gimg/www.cor...5346a1ff08.jpg |
Wheel Make: CCW
Wheel Model: SP 16a Front Size: 19" x 9.5" with 1" lip Front Offset and Backspace: +52 with 7.30" backspace Rear Size: 19" x 11" with 2" lip Rear Offset and Backspace: + 64 with 8.15" backspace Front Tire Size: 265/30/19 Michelin Pilot Super Sports Rear Tire Size: 305/30/19 Michelin Pilot Super Sports Suspension Mods: None - stock ride height. Problems or Issues: None - tires do not stick out past bodywork Misc. Comments: Great package just a lot of work to keep the wheels clean - designed for big brake package but I like to run my stock wheels as well so probably not |
Wheel Make: Forgestar
Wheel Model: F14 Front Size: 18x9.5 Front Offset or Backspace: +50mm Rear Size: 19x11 Rear Offset or Backspace: +55mm Front Tire Size: 265/35R18 Rear Tire Size: 305/30R19 Suspension mods: Lowered on stock bolts Problems or Issues, such as clearance/rubbing problems: None |
Wheel Make: Cray
Wheel Model: Manta Front Size: 18x9 Front Offset or Backspace: 50 6.900 Rear Size: 19x10.5 Rear Offset or Backspace: 65 8.300 Front Tire Size: 265/35/18 Nitto NT555G2 Rear Tire Size: 305/30/19 Nitto NT555G2 Suspension mods: Lowered on stock bolts Problems or Issues, such as clearance/rubbing problems: None Misc.Comments: New tires updated |
Wheel Make: CCW
Wheel Model: SP500 Fully Polished Front Size: 19"x10" 2" LIP Front Offset or Backspace: 7.75" BS Rear Size: 19"x11.5" 3" LIP Rear Offset or Backspace: 8.65" BS Front Tire Size: 295/30/19 Hankook Ventus V12 Evo2 Rear Tire Size: 325/30/19 Hankook Ventus V12 Evo2 Suspension mods: Lowered on stock bolts Problems or Issues, such as clearance/rubbing problems: No rub and clears Z06 brake ducts Misc.Comments: 2002 Z06 https://cimg9.ibsrv.net/gimg/www.cor...170d53b50a.jpg https://cimg3.ibsrv.net/gimg/www.cor...c000952372.jpg |
Wheel Make: Ace Alloy
Wheel Model: AFF06 Front Size: 20x9.5 Front Offset or Backspace: +30 Rear Size: 20x12 Rear Offset or Backspace: +40 Front Tire Size: 285/25/20 Rear Tire Size: 325/25/20 Suspension mods: Bilstien B8 Shocks, Lowered on stock bolts Problems or Issues, such as clearance/rubbing problems: None Misc.Comments: '99 FRC, the Michelin Pilot Support Sports on the Ace Alloy wheels feel amazing!!! Like a million times better than stock. https://cimg7.ibsrv.net/gimg/www.cor...8394fec9bf.jpg https://cimg0.ibsrv.net/gimg/www.cor...113fdd13a6.jpg https://cimg2.ibsrv.net/gimg/www.cor...ec5ba9502a.jpg https://cimg4.ibsrv.net/gimg/www.cor...96aa2e622e.jpg |
Wheel Make: CCW
Wheel Model: SP500 w/Big Brake Clearance Front Size: 18x9.5 Front Offset or Backspace: +48 Rear Size: 19x11 Rear Offset or Backspace: +54 Front Tire Size: 275/35-18 Michelin Pilot Sport PS2 Rear Tire Size: 305/35-19 NItto NT05R Suspension mods: Lowered as low as stock bolts will allow, F45 Delete, Bilstein HD Shocks Problems or Issues, such as clearance/rubbing problems: None except the rear tires don't lend to wet weather driving **Updated pics to better shots to show the wheels better.** https://cimg2.ibsrv.net/gimg/www.cor...0794986ca2.jpg https://cimg7.ibsrv.net/gimg/www.cor...62fdc42079.jpg |
Wheel Make: TSW
Wheel Model: Nurburgring Front Size: 9x17 Front Offset or Backspace:50 mm Rear Size:10.5x18 Rear Offset or Backspace: 65mm Front Tire Size: 255/40/17 Rear Tire Size: 295/35/18 Suspension mods: Stock, C6Z06 Swaybars and shocks Problems or Issues, such as clearance/rubbing problems: none Misc.Comments: https://cimg9.ibsrv.net/gimg/www.cor...8e16ae95d.jpeg |
4 Attachment(s)
Wheel Model: CF5 (textured bronze) Front Size: 18x9.5 Front Offset or Backspace: +50mm Rear Size: 19x11 Rear Offset or Backspace: +55mm Front Tire Size: 275/35/18 Rear Tire Size: 305/30/19 Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: HSD Coilovers Problems or Issues, such as clearance/rubbing problems: no issues Attachment 48348635 Attachment 48348636 Attachment 48348637 Attachment 48348638 |
Tire specs
Make: Wheel Model. Michelin super pilot sports
: : Rear Size: Rear Offset or Backspace: 325 30 r 19 on an 11 inch rim. Suspension : zo6 suspension Problems or Issues, such as clearance/rubbing problems: Misc.Comments: No problems great tires great 11 inch rims nothin protruding nothing rubbing. |
https://cimg3.ibsrv.net/gimg/www.cor...ed2600dad.jpeg
Wheel Make: CCW Wheel Model: 505A Front Size: 18” x 8.5” Front Offset: ET 48mm Rear Size: 19” x 10” Rear Offset: ET 68mm Front Tire Size: 245/40/18 Rear Tire Size: 285/35/19 Suspension Mods: C6Z06 shocks; lowered ~ 3/4” on stock bolts. Problems/Issues: None. |
Wheel Make: Cray
Wheel Model: Brickyard Front Size: 19” x 9” Front Offset: +57mm Rear Size: 20” x 12” Rear Offset: +59mm with 20mm rear spacers Front Tire Size: 275/30/19 Rear Tire Size: 345/25/20 Suspension Mods: Stock. lowered with aftermarket bolts (C6 front bolts, longer bolts on the rear) Problems or Issues, such as clearance/rubbing problems: None https://cimg4.ibsrv.net/gimg/www.cor...1e3e8ed16.jpeg |
Wheel Make:360 Forged
Wheel Model: Concave Mesh Front Size: 19” x 9.5” Front Offset: +57mm Rear Size: 20” x 12.5” Rear Offset: +33mm Front Tire Size: 275/30/19 Rear Tire Size: 345/25/20 Suspension Mods: Stock. lowered with aftermarket bolts (C6 front bolts, longer bolts on the rear) Problems or Issues, such as clearance/rubbing problems: None https://cimg6.ibsrv.net/gimg/www.cor...90faf2dab.jpeg |
Wheel Make: CCW (WCC centercaps - I assume they were ordered through West Coast Corvettes)
Wheel Model: 505a Front Wheel Size: 19x10 Front Offset or Backspace: unsure - wheels were on the car when purchased Rear Wheel Size: 19x11 Rear Offset or Backspace: unsure - wheels were on the car when purchased Front Tire Size: 275/30/19 Continental Extreme Contact Sport Rear Tire Size: 305/30/19 Continental Extreme Contact Sport Suspension mods: Stock, Lowered on stock or aftermarket bolts, or coilovers: Lowered on stock bolts Problems or Issues, such as clearance/rubbing problems: No issues Misc.Comments: https://cimg0.ibsrv.net/gimg/www.cor...78e20a18bc.jpg https://cimg9.ibsrv.net/gimg/www.cor...0969c85b2a.jpg https://cimg4.ibsrv.net/gimg/www.cor...ef44166c4b.jpg https://cimg5.ibsrv.net/gimg/www.cor...06c9238c00.jpg |
Wheel Make: CCW
Wheel Model: SP500 (Polished and Gloss Black versions) Front Size: 19” x 10” Front Offset: Not sure (don't remember exactly) Rear Size: 19” x 11.5” Rear Offset: Not sure (don't remember exactly ) Front Tire Size: 275/30/19 Rear Tire Size: 305/30/19 Suspension Mods: Stock. lowered with aftermarket bolts (C6 front bolts, longer bolts on the rear) Problems or Issues, such as clearance/rubbing problems: None https://cimg3.ibsrv.net/gimg/www.cor...37e9c72f3.jpeg https://cimg4.ibsrv.net/gimg/www.cor...67e8b73ef.jpeg |
1 Attachment(s)
Wheel Make: CCW
Wheel Model: SP500 Gloss Black Front Wheel Size: 19x9.5 - 1" Lip Front Offset or Backspace: +48 BS 7.125" Rear Wheel Size: 20x12.5 - 3.5" Lip Rear Offset or Backspace: +35 BS 8.125" Front Tire Size: 275/30/19 Rear Tire Size: 345/25/20 Suspension mods: Aldan coilovers Problems or Issues, such as clearance/rubbing problems: N/A Misc.Comments: Setup for C6 Z06 brakes F+R and 2" flared rear quarters. P.S. I added functional all GM parts, Z06 rear brake ducts, in place without issues. |
