Major issues with weatherstrip.
Has anybody else had issues with reproduction weatherstrip lately? My 67 coupe doors fit perfect when I took them off. I put them back on and did a little gap work and after adding the weatherstrip for final fitment, they won’t even close unless I slam the sh*t out of them. I ordered the weatherstrip with the molded rear corner from corvette central. Something is horribly wrong with it and the mounting surface for the weatherstrip is squared off rather than coming to a peak or point.
Originally Posted by 65silververt
(Post 1598902723)
Besides checking who made the weatherstrip, and considering changing if not CR, I have no other solution or advice. :D Larry |
I didn’t notice the difference in the back until I ripped it back off. Looks more like Jeep weatherstrip than the original corvette weatherstrip. Another f up by Corvette central. I’m done with them for good!
I did use the CR weather strip on my '61 back in 2009, and the doors "did" take some persuasion to close, for several weeks. The first week was the worst. Its all copacetic now, and has been for years, as the WS compressed to its final form. I also didn't have the top window coupe surround to add to the closing pressure needed.
Doug |
I believe my painter recommended corvette rubber as well.
c2 weatherstrip
I did the weatherstrip on my 63 SWC a few years back. For the first few weeks, I had to force the doors shut. After a few weeks, they were fine. Just had to compress the polymer for awhile,
Jim |
Corvette Rubber has long been the "gold standard" for our cars and what is on my 63 with the ONE exception being the coupe upper horizontal door ledge rubber which came from Zip. It was a pleasant surprise as it was correctly formed and sized and quite supple...
Without seeing the weather strip I have no idea if it's substandard or not - but, even with good quality weather stripping it is difficult to get the coupe doors to shut for awhile. Don't slam them as that's a good way to get cracks in your paint around the door handles (if using the handles) and shaking the heck out of the door innards. Instead, move the striker out to where the door close with a reasonable level of effort and leave it like that for a month or so. Then set the striker back a slight amount to where the doors will still close reasonably easily and again, let it set for a month or more. It may take 4-6 months of this - maybe even longer in worse cases - before you can gradually creep the striker back to where it should be, the weather stripping compresses/conforms and the door close normally and fit properly.
Originally Posted by DansYellow66
(Post 1598903511)
However I've heard of some that put ratchet straps through the coupe windows and snug them down over the roof to pull the doors in over time and force the rubber to take a "set"...I'm not that brave... |
https://cimg9.ibsrv.net/gimg/www.cor...7027797d9.jpeg
When I say they won’t shut, I mean they won’t shut. This isn’t a minor “break in” issue, trust me. 😬 |
Weatherstrip before paint ? I’m no restorer but is that how it’s done ?
Originally Posted by Frankie the Fink
(Post 1598906625)
Doug |
Try www.steelerubber.com . Their weatherstrip is correct and will fit properly.
(Post 1598906625)
Originally Posted by AZDoug
(Post 1598906914)
It's RatRod Corvette.:) Keep painting costs below $25K.
Doug |
(Post 1598907671)
i always fit the doors and other parts with weatherstrip. Then it’s removed and I install new weatherstrip after paint. It’s worth the extra time.
Works best with good weatherstripping before and after paint no doubt... |
(Post 1598907738)
OK - got it....
Works best with good weatherstripping before and after paint no doubt... Thanks for the replies! I will try Corvette Rubber |
(Post 1598906625)
Originally Posted by J.Abbott
(Post 1598909666)
Actually that is how it is supposed to be done. You buy two sets of W?S if needed. You install it and do all your body work. Then you pull it off and paint the car. You should put the whole car together before you paint it to make sure everything fits perfect. That is why a really nice paint job is really expensive.
(Post 1598902723)
