Center hvac grill mounting screws
1996. Does anyone know the size of the mounting screws than go to the center hvac vent grill. I’m taking grill off as part of climate control head removal and would like to have new screws to put back in. Thanks
Small with feet so they can run and hide from you. A dab of black model paint will cover screw driver witness marks. You could also remove 1 and match it at hardware store.
Thanks
I know I can dab a little paint on them, not sure about getting at hardware store but will see. Another stupid question regarding the shift plate and it’s rubberized coating.. what touch up paint would you recommend to cover some blemishes. I’ve seen shift plates fir sale and actually bought one but they don’t match rest if interior so I sent it back
I havent looked for a while, ebay had "screw kits" for reasonable prices. maybe not the OEM exact part.
These were clean and fit well. |
My recollection they are pretty specific with a torx head and small captured washer. They are pretty well hidden, any reason for new.
Just cautionary. I started taking them out to remove radio and climate control bezel to remove climate control head and repair it. Screws coming out if the vent grill are extremely hard coming out so I stopped. Just afraid I might bugger up screws by the time I get them out
You will break the plastic before you break the screw. That is if you have the bit completely seated in the screw head.
Size of torx
So I don’t mess up heads does anyone know what size torx heads are for the two screws that’s have to be removed?
Originally Posted by Ray0214
(Post 1598946248)
New ones that you can buy from many on-line vendors claim the finish matched OE, but they don’t at all. They are more if a matte finish. I was able to find a used one that has the exact matching finish that’s on my corvette. I haven’t put it in yet. I was curious if anyone knew the torx head size of the center a/c vent that has to come off, as I don’t want to bugger up the head of the screws by experimenting on the torx size
Originally Posted by FresnoVette
(Post 1598957467)
I haven't looked for a while, ebay had "screw kits" for reasonable prices. maybe not the OEM exact part.
These were clean and fit well. Here is the list of what is included https://cimg7.ibsrv.net/gimg/www.cor...5f0cab60a1.jpg |
Originally Posted by Gunho
(Post 1599047420)
someone on here had his bead blasted. Took the rubberized coating off to bare plastic. It looked like new. For 94-96 you can buy new. But for a 93, they are hard to come by....
here is a before/after of my plate https://cimg0.ibsrv.net/gimg/www.cor...d021a8876a.jpg |
I used plastidip on my shifter trim. It worked wel.
Color?
Looks good, which plastic coat did you use? Flat, matte, gloss??
