2007 Z06 - 100K Mile Tune Tips
I've got a 2007 Z06 that is about to turn the century mark at 100K miles. I have always done all of my maintenance and the car has been a dream to own in terms of reliability. From a performance perspective I would say she runs as strong now as she did from day one over 11 years ago. I was curious if anyone had any suggestions for tune up or replacement items, other than the GM recommended. I'm in the middle of sinking $50K into a 69' Camaro build at the moment so I'm only looking at stock service / replacement tips for now. Specifically interested if there are any suggestions relative to injector service or replacement.
Valve job.
Thanks for the feedback however it's kinda hard for me to justify the money to "break the seal" on the top end without going deeper (not that I wouldn't enjoy it). That said, I know the LS7's history and you are right, probably worth spending the time / money.
Just change the wires and plugs and whatever fluids you feel like doing.
one owner ls3 c6 z51 now at 130k. these cars are built extremely well. just regular maintaince and add gas, enjoy |
Originally Posted by Troika
(Post 1598944891)
Thank you, I did the plugs at about the 75K range but the wires are a good suggestion,
Thanks again. That's a hot tip on the ultrasonic testing, I was just reading an article about that. I've kept all the fluids fresh through the years on my own schedule which exceeds GM's recommended intervals by a bit.
BG44K and BG EPR, are two products that we use and recommend. 44K every 4-5 fillups, EPR every 4-5 oil changes, these are not snake oil, they are proven products, I use them in my own vehicles and sell them at my shop.
At 100K and assuming no service work other than oil and spark plug changes have been done...
Flush the brakes Change the rear axle lube. Change the trans lube Change the power streering fluid. Replace the drive belts Replace the plug wires Replace the clutch disc Do a four wheel alignment Replace the cabin air filter Pull the injectors and have them cleaned |
Originally Posted by Hib Halverson
(Post 1598948160)
Flush the brakes Change the rear axle lube. Change the trans lube Change the power streering fluid. Replace the drive belts Replace the plug wires Replace the clutch disc Do a four wheel alignment Replace the cabin air filter Pull the injectors and have them cleaned I appreciate the feedback from those that have taken the time to comment. Possibly one of the more boring tech questions however it's always good to hear from others because there's usually something obvious that we overlook. |
Does your car have the stock heads as delivered? The reason I ask is because some cars have experienced valve guide issues as we all know. It would be comforting to hear from folks that have stock, untouched heads and higher mileage. Just curious and congrats on making it to 100K without any major issues...good to know.
I appreciate the sensible request and helpful responses. My 2007 Z06 currently has ~82k miles with only regular maintenance (plus a thorough valve-to-guide clearance "wiggle test" at 62k miles for peace of mind). I will follow your lead as it approaches 100k miles and hopefully see another 100k without becoming a statistic in the mileage before LS7 engine failure stock thread.
Meanwhile, your last post piqued my interest about losing a clutch while descending Pike's Peak. What happened? |
Originally Posted by MAD Matt
(Post 1598952366)
I'm aware of the valve guide issue and I guess all I can say is, as I pass the 100K mile mark, I'll keep my fingers crossed. |
Originally Posted by bjmsam
(Post 1598952436)
(Post 1598952366)
Dang, that 69 camaro build tho!
I have a 68 Camaro you could have for $35 instead :D |
