Butcher-shop repair? Any guesses what the damage was?
So there are two almost identical repairs on my rear fenders and they both look like total garbage but what I can't figure out is what was being repaired in the first place??? Maybe it bottomed out and tore the fenders?
What would a proper body shop do with this now? https://cimg2.ibsrv.net/gimg/www.cor...a76d2b836c.jpg https://cimg3.ibsrv.net/gimg/www.cor...e591fa2e8b.jpg |
Little known "aero" add on. Said to increase top speed by .12 mph, all the fast cars have them.
Yikes, that don't look so good. |
Originally Posted by Black 03 Z06
(Post 1599016213)
Yikes, that don't look so good. It's more noticeable in certain light and angles, but yes it's terrible looking regardless. Should I put hash mark stripes over it? Lol |
I would jack it up and take inner wheel well liner out and look at the back side of fender.
Originally Posted by 68ssconv
(Post 1599017391)
The question now is, would it be cheaper to fix or to just replace with a good set of panels and have them painted to match? |
Originally Posted by Jackie N
(Post 1599017497)
Being so close to the edge of the wheel well lip...getting the silver to match and blend out should not be a problem...BUT....that also depends on what happens when I sand these areas to see what is going on under them. And....obviously the quarter panel would be clearcoated. Due to trying to blend the clear would more than likely not work well and the line where the clear would stop would show up. DUB |
Originally Posted by DUB
(Post 1599017588)
I would have to sand down those humps and see what it looks like under it AFTER I had looked on the backside of the panel so see what it looks like.
The only problem with replacing the quarters is paint match. You may have to blend on the doors and trunk with base coat and clear it all, way more cost.
(Post 1599020102)
DUB |
(Post 1599022744)
:iagree: 'Thinking' that you can get the silver and paint new panels and they are going to perfectly match your car now....guess again. The odds are greatly stacked against you....kind of like a blind squirrel can find a nut every once and a while. Doing something like this may work...every once and a while but not normally. Too many variants in the silver and its age.
DUB Dub, would you then say that a spot repair is the safest way to proceed? It's easier to blend the spot to the rest of the fender than to blend the whole fender to the rest of the car? |
I would repair it and blend the paint in the quarter
I want to see what was done Grind it down My guess is there is a hole there and bubba tried a patch |
I don't know how whoever did the repair wasn't completely embarrassed after it was done lol
I’m not defending the person who did the repair, but it was probably good when they did it but over time the repair lifted probably not good adhesion maybe they tried a new product. When it comes to paint and body work there is lots of variables. After I do all my bodywork I try to let the car sit for at least a week to let it get good and dry and even after I prime I let it sit. If it’s a nice hot sunny day roll it outside let it get good and hot so if you do have a problem you will see it before you paint. I used to work with a guy and everything he touched fish eyed it was his cologne.
Still not knowing what the back side of the quarter looks like in the area of this 'repair'....there is no way in knowing what is going on there until you begin to sand or grind it down.
Then this can possibly open up Pandoras box. Never knowing what the previous person has done...and IF they properly prepped the panel prior to applying the silver paint you currently have on the quarter now....because you would be shocked on how many people do not even scuff paint when they go to put paint on top of it....which.can cause for a totally different route of repair IF they did not correctly prep the panel prior to them painting it silver over this 'repair'. DUB |
