89 383 Convertible fully built toy car + (SOLD)Hardtop $6200 - Denver
UPDATE: HARDTOP SOLD
UPDATE2: VETTE SALE PENDING https://cimg2.ibsrv.net/gimg/www.cor...362d44c328.jpg https://cimg8.ibsrv.net/gimg/www.cor...720d3f1a6e.jpg https://cimg9.ibsrv.net/gimg/www.cor...fc148dad5e.jpg 132,400 miles ENTIRE driveline replaced since 121,000 miles 383 built by Jeb Burnett (Corvette Forum) with Lingenfelter Super Ram intake Balanced and Blueprinted Forged Pistons Cast Crank 1.6 Roller Rockers Custom cam, similar to ZZ9 High Flow oil pump Hi-Cap Moroso Oil pan McLeod Hi-Torque starter Supplemental Oil cooler with 170 degree thermostat Hooker Supercomp long tube ceramic coated headers, Magnaflow mufflers and new EPA stamped cat. Dana36 Rear-end cryo’d and blueprinted by Jeb Burnett 700r4 built by Hartman High Performance (Syclone/Typhoon forum) Billet 9/11 torque converter with 3200 stall by TCS B&M Megashifter Supplemental Transmission Fluid Cooler and Temp Gage Tuning by Ed Wright at Fastchip Roughly 12,000 miles on engine, transmission u-joints, rear-end, Uprated Cooling system, Poly-graphite bushings, coolers for oil and transmission fluid, remote oil filter C5 front brakes, 92 Camaro uprated master cylinder 3.52 rear-gears + Dakota Digital speedo corrector Griffin Radiator, high-flow water pump and Evans NPG non-aqueous coolant, kit from www.evanscoolant.com Redline f-type transmission and Heavy Shockproof gear lube Extras: Seperate Seasoned, Numbers-matching block Factory Service Manual OBD1 Auto X-ray Spare tire and hanger (removed from vehicle) Newly replaced headlight motor gears Pending SALE SEPERATE SALE: Dark Red Hardtop with all brackets and hat shelf carpet - 9/10 condition, local pickup only, for $1200 - price of Vette will drop to $5000 Vehicle is in Denver, Colorado DOES NOT PASS DENVER METRO AREA EMISSIONS - Vehicle has a new EPA compliant CAT fitted and Cam Profile was selected to pass emissions, and did so until 2011. Vehicle is healthy, rumor is that they lowered the HC limits. It burned 2.94 HC, 13.1174 CO, 484 CO2, and 0.8025 NOx - It needs a line from the AIR pump to the Cat to pass the visual inspection. Purchase by someone in the Denver Metro Area will include forms stating the sale occurs with a non-emissions compliant vehicle. This is only relevant for sales in the following counties:
Any 1/4 mile times ?
Nice! What are the street manners like on this car?
1/4 mile times need to be prefaced with the Altitude. Street tires, at Bandimere, it turns sub 2 second 60 foot times, and has turned high 13's. It's a snapshot of it's time, not as fast as a lot of stuff out there, but it was built for torque and is a really fun car to mess around in.
Expect mid to high 12's at Sealevel, traction limited. :D Street Manners are really good. The 9/11 torque converter was the trick at the time to raise the stall to 3200 rpm, but not feel sloppy on the street. Additional cooling was added to combat the elevated fluid temps you'd see in stop and go traffic. It's not idiot-proof (watch the tranny temps), but aside from that, it'll cool and run and start and race dependably. |
The Initial Post was missing some detail (car was on the lift, in the dark) He're some more interior shots and startup. It always start on the second turn of the key.
https://cimg8.ibsrv.net/gimg/www.cor...d4968130ad.jpg https://cimg3.ibsrv.net/gimg/www.cor...0f821e5b44.jpg https://cimg9.ibsrv.net/gimg/www.cor...3513a0570c.jpg |
Hi! Was wondering if you would be interested in a part trade? I have a 93 six speed roadster with Dana 44 and 345 gears. Car looks and runs good. Lot of miles. 156k. Also have a 85 coupe looks and runs good with 94k. It's the 4-3 transmission with Dana 44 with 307 gears. Would be throwing some cash your way as well??? Let me know if you might be interested. I can send pics if you want. Thanks.
Gary |
Originally Posted by GaryInArizona
(Post 1599262151)
Gary |
OK very interested in your car if I get these sold and you still have your car I will let you know. Thanks Gary.
Cool. It's goin on Craigslist later this week.
HI still have your car ?
I do!
Good think I might have my car sold if it sells I will let you know. So what would your bottom dollar be with out hard top ? Thanks Gary
I sent you an DM...did you get it?
I got your email and sent you a reply. I haven't sold my car yet. Will contact you when I do to see if you still have your car. Thanks.
Gary |
Did you sell it ?
(Post 1599360783)
Did you sell it ?
Darn it just sold my car. I'm sure the new owner will be happy.
(Post 1599361689)
