where is the underhood light?
like the title say when the hood is open i cannot find any lights. 2011 GS vert.
There isn't one.
Originally Posted by 919cw313
(Post 1599201586)
There isn't one.
AFAIK the factory installed light was discontinued after 2006 MY. I don't think they ever got rid of the connector though. Some have installed them on later years, usually along with the crossed flags hood liner. That said, the light is mostly useless and you're better off with a flashlight.
Not sure when they stopped putting them in but my 2007 does not have an under hood light
My 07 Narrow bodied car didn't have one and neither does my 10 Grand Sport.
Originally Posted by captain vette
(Post 1599201640)
this is not what my owners manual say.
Originally Posted by my1970conv
(Post 1599201737)
What page in your owner's manual does it say there's an underhood light? I'm looking at a 2011 owner's manual, and I don't see it.
(Post 1599201832)
6-9 if you have a french version of the o-m.
So I think the confusion is simply the words "le cas échéant", which means "if your vehicle has this feature"... Here's the same phrase in english... "This vehicle has a feature to help prevent the battery from being drained in case any of the following lamps are left on: the underhoodlamp, if your vehicle has this feature, vanity mirror lamps, cargol amps, reading lamps, console,or glove box lamps. Simply put, C6 Corvettes after 2006 (I believe) no longer has this feature. |
If you buy the correct hood liner you can add it back. The connector is still there.
I find the factory installed under hood light in my car is a pretty handy option to have
(Post 1599201714)
https://cimg0.ibsrv.net/gimg/www.cor...7a8d2edebd.jpg |
My 2007 has the light.
My 08 does not have the light but the connector is there. My buddy’s 07 has the light.
They deleted the light (but not the connector) about a third of the way through the 2007 model year.
Light was deleted because it was causing many new Vettes to be delivered to the dealership with dead batteries.
(Post 1599202328)
Hi captain vette... so I can see page 6-9 in french, and yes it says 'Le véhicule est doté d'une fonction empêchant la décharge de la batterie au cas où les lampes suivantes sont laissées allumées : la lampe du compartiment moteur,le cas échéant, les lampes depare-soleil, les lampes de l'espaceutilitaire, les lampes de console, leslampes de lecture ou les lampes deboîte à gants.'...
Originally Posted by bobeyoung
(Post 1599202538)
my 07 does not have a light. |
Originally Posted by Vette_DD
(Post 1599202700)
My 05 has it, and no you can't have it. :D
