Front spliter instaal Q&A
Purchased a MagicDrift ZR1 front splitter for base C6, seems the fit is not all that great and the 3M tape is crap. Any helpful tips on the install? Seems like a three person job to line up the center and ends correctly. Thanks
I have not done that splitter you're asking about but I have done splitters. grab a roll of painters tape. tape one end in place, then the other end, then the middle. Makes it a one person job.
https://cimg0.ibsrv.net/gimg/www.cor...e22d5abe0.jpeg
https://cimg8.ibsrv.net/gimg/www.cor...2bea2ddd3.jpeg I have the extreme online store one. I just started at one end kinda taped it up first. Then drilled it and self taped it in and worked around to till I gor to the other end. |
I had extreme online and needed to form my passenger side with a heat gun. Makes it pliable and was able to make it work
1: Lay on flat surface in direct sunlight for several hours. Use weights if necessary to keep it flat.
2) Buy 3M emblem tape and a box of their adhesion promoter. Don't use regular double sided tape for anything more than test fitting. 3) Work from the center outward. Drill a hole for the center and secure in place as you complete the test fit. 4) You may need to use screws to secure the side trim to the bumper. 5) Either have it professionally painted, leave as is or go plasti dip. https://cimg3.ibsrv.net/gimg/www.cor...b94c85b4be.jpg |
Now get the oracle side marker leds
https://cimg3.ibsrv.net/gimg/www.cor...b3509e530f.jpg https://cimg6.ibsrv.net/gimg/www.cor...56275a552b.jpg
Originally Posted by cart7381
(Post 1599216493)
