Power / Ground Terminal - options?
I am not a wiring guru. It is never pretty, per se, but it is always functional when I do wiring.
That said, I have a DD dual din dash with the tri-gauge pod mounts across the top. I am going to swap this from my 99 to my "new" 03Z. In so doing, I want to avoid the absolute HORROR SHOW which is the wiring located behind the dash. One space saver is not having to use the PAC bose adapter this time through since I'll use an amp. Does anyone have examples of remote "terminals" I can install for + and - feeds? Locations to run power and ground from to the center console? Instead of sloppily trying to wire things together in-line, my concept is to have a ring end terminal or other (I don't know what products exist for this purpose) and keep it both neat and also readily changeable if or when needed. Drop some knowledge on this unedumacated fool. Pictures & Product Links appreciated. |
I use Blue Sea fused distribution blocks and euro barrier terminal strips for this sort of thing.
https://www.bluesea.com/products/cat...locks/ST_Blade I really like the euro barrier strips because you can easily cut them for whatever the application is. If you want to use it for distribution, you just loop a wire along one side in and out of each terminal, then put your loads in the opposite side. The fused blocks are really nice too - this way you can make sure that all of your equipment is protected. I had one of them with power and ground and I modified the powered part so that half worked with key off and the other half turned on with the ignition utilizing a relay. |
Looks like a good way to join one-to-one lines. I picked up a few of those screw terminals.
What I was picturing though is more like the accessory power bracket bolt under the hood... A bolt with some sort of surround which will accept multiple attachments. Then the same thing for a ground connection nearby. I pulled my head unit and gauges last night and there are just too many Ys into other Ys. I did it fast and sloppy. I don't want to do that again. I can picture the product I have in mind, I just down know how to search / find it or what the correct terms would be. |
You're talking about a bus bar...
https://www.westmarine.com/buy/blue-...hoCew4QAvD_BwE ...however, I would definitely recommend using the fuse blocks linked above on the positive side. You want to make sure all those circuits are fused, and its much easier to use the standard mini fuses than try to fiddle with inline fuses on each one. |
Really the fuse blocks are the best thing to use. There are much cheaper versions than the bluesea ones on amazon.
I guess I also didn't describe very well the way I use the barrier strips for multiple circuits fed from one source. Here's a picture: https://cimg6.ibsrv.net/gimg/www.cor...55216780d4.png There are also different types of barrier strips with jumpers. This is kind of the same concept I was trying to explain with the euro barrier strips but maybe a little cleaner. You could use one for power, one for ground, or cut the jumpers and use half for power half for ground. Could be configured however you want pretty easily. IMO a bolt with multiple ring terminals on it is about the ugliest way it can be done. Also you should not overlook the need for fuses. Ideally each branch circuit has its own fuse. |
Originally Posted by daverulz
(Post 1599237436)
I use Blue Sea fused distribution blocks...
https://cimg4.ibsrv.net/gimg/www.cor...a65b10bd26.jpg |
The more I thought about it, the more I like the BS unit for having the fuses. That seems common sense. I did order a 6-circuit piece as that will serve my needs directly. Thanks for the good recommendations here.
C5 5 volt connection
wrong thread, sorry
