1975 auto neutral safety switch
I am trying to finish up a winter project of putting in new carpeting in my 75 auto and figured I would tackle why my reverse lights are not working. I know it is tied into the neutral safety switch so when I went to investigate i noticed that it has been bypassed. I see how the purple wires go together, but I can not find any other connector for the bundle of pink wires. The green/pink wires are already connected together. I also have 2 other connectors that lead a bit further back that I have no clue where they go. Any help would be appreciated.
https://cimg8.ibsrv.net/gimg/www.cor...6669ef674.jpeg https://cimg0.ibsrv.net/gimg/www.cor...da2d3b020.jpeg |
on my 72...
The green and pink wires are the reverse lights, only show continuity in the reverse gate position The pink w/white and pink (same pink wire as above) wires show continuity in drive (3,2 and 1) so they must be related to the seat belt reminder circuit M |
The 75's had that goofy seat belt interlock system. Someone was probably trying to bypass that system.
Mike |
Thanks for the information. I tried hooking up the purple wires and the car would not start, I’m not sure if the switch is bad or not. I don’t see how the gear shifter and switch interact with one another, any ideas? I hate to put it back together with it bypassed and I also hate to spend $100 on a switch that doesn’t need replacing
The switch has a tab on the underside that goes onto a pin that's on the shifter
https://cimg9.ibsrv.net/gimg/www.cor...642382a524.jpg You can easily test the switch with a meter or test light & some jumper wires to see if it connects in the park position, there is some adjustment in the position as well More picks here if needed https://www.corvetteforum.com/forums...post1589170231 M |
