Alignment shop
I’m looking to have the 1973 Vette with a 4 wheel alignment job, or at least try if there’s a shop that knows what they’re doing. Any of you Tampanians (Tampa, Fla.) out there knows of and recommends a shop for this? Been here only 2.5 years, and still feeling my way around. Any info on this is appreciated.
Van Steel is in Clearwater. They should be able to tell you where to go if they don't do it themselves.
https://www.vansteel.com/ |
Thanks, will give them a call and ask
Originally Posted by 73VetteRay
(Post 1599373821)
If they don't ask you. Are you supplying the shims for the rear trailing arms. or ask them if they stock the shims for the rear trailing arms. If they give you a dumb look they will only adjust rear camber and front toe. No front caster / camber and most important no rear toe adjustments. So before getting your alignment have a complete shim kit for the shop to use. Count the total shims and check what they used. |
Originally Posted by cagotzmann
(Post 1599375704)
Here is the easy way to determine if they know how to do a complete alignment.
A
Originally Posted by bruiser
(Post 1599374130)
Call Advanced Performance on Linebaugh Ave. Mike owns the shop and does all of my cars. If you want him to do the rear, make sure the bolts and shims are not rusted. PM me for further information. Jerry
Originally Posted by Tampa Jerry
(Post 1599379865)
I live just 40 min north of Tampa. These are all good leads. Get a printout before and after and watch them. Bring a shim kit and long cotter pins. Make sure there is no positive camber on the right front. These roads are crowned for all the rain down here and will smoke the RF tire off.
I would be interested in what machine/method the shop you choose uses. I just replaced TA bushings and finished up my DIY alignment. Used string to get thrust and toe close. Started building tools for laser level method. Have digital angle meter for camber. Caster...well thats another story. Anyway a shop here has a new alignment machine and offered to align my car. I know the owner so I will be there and assist with the process.
Don't forget to down load the alignment specs you want the tech to use. You can get the specs on the C-2 forum. I think Van Steel also has alignment specs as well. Jerry
I worked down in West Palm for 20 years. 77-97 Did 22k alignments. I have only been in the Tampa area a couple years so its all been hearsay. Their machine may or may not have specs. Doesn't really matter. Bring your own spec sheet. The specs are too generous and could cause issues anyway . On the front go -.50 degree neg on the right front. .00 to .25 positive on the left front. Total toe 1/16 th in. Caster .50 degree more positive on the right side or she will pull.NO negative caster on either side. Rear neg on both sides camber .50 or a little more if you want to super handle on turns. 1/16th total toe rear is good also.
Originally Posted by 71convertible
(Post 1599400507)
(Post 1599402105)
Yeah,. Love these cars but, geeez, it never ends. Thanks
(Post 1599400656)
(Post 1599400724)
Originally Posted by jim2527
(Post 1599402164)
I work in the medical field and tell people that old cars are like old people, “there’s always something going wrong”
