Crank Hub install
Engine is not at top dead center would this be the correct way to install the Hub to then set it at top dead center?
https://cimg0.ibsrv.net/gimg/www.cor...958526c9ed.jpg Putting Hub on is this correct? https://cimg9.ibsrv.net/gimg/www.cor...ced9300b85.jpg Crankshaft |
The hub isn't keyed. The front half on the engine is supposed to be neutral balanced , so orientation isn't important.
There is a note: If a vibration is noticed, set #1 to TDC and pointer to 12 o'clock, and reevaluate. |
If you look inside the hub. You should see where the key way was originally. I just did this a couple months ago and had the same question
Awesome thank you both so much!
