Clutch Install Question
Hello. I am going to be doing a clutch install on my 2011 GS in the next couple of days and I have a question.
Is it necessary to remove the mufflers/rear exhaust or can they stay in the car? The reason I ask is when I did a clutch install in my C5 Z06, I left them in and just zip tied them out of the way. I have done a C5 clutch install and I have read the excellent clutch install write-up by member rpmextra located at this link: C6 clutch replace with full pics I don't have a lift so will be doing this on jack stands and am trying to save myself any extra work I can. (Going to be installing a Monster LT1-S twin disk as I think my stock clutch is slipping since I installed an E-force.) |
Let me know how you like that clutch. I've been eyeballing that one for my GS of my stocker flips upside down
I think you have to remove the mid pipe at least because of where it runs in relation to the driveshaft. Do a search and there should be a full write up on replacing the clutch on a C6. Pretty good details.
Originally Posted by Spaceme1117
(Post 1599567964)
....Is it necessary to remove the mufflers/rear exhaust or can they stay in the car? The reason I ask is when I did a clutch install in my C5 Z06, I left them in and just zip tied them out of the way.
I have done a C5 clutch install ..... Jack stands are high enough if you're going to do it that way. If I remember I had about 23" of height. |
Originally Posted by Dutch08
(Post 1599569661)
I have done both a C5 and C6 and they are nearly the same. I removed the mufflers (the entire exhaust) both times as to me it is almost no amount of extra work compared to the job of changing the clutch. Also the on the C6 mufflers are in the center could be in the way when you're trying to back out the trans and torque tube.
Originally Posted by jaybee924
(Post 1599568697)
(Post 1599570203)
Ah, okay then that makes sense. I will probably have to lower the rear cradle and then remove the rear mufflers. Thanks.
Ohhhhh wait a minuted I didn't think of that. Do you still have the stock mufflers on??? I believe the over the axle part is welded on to the muffler. You will probably definitely have lower the cradle if you are on jack stands to get the mufflers out. I have after market CORSA mufflers and the over the axle pipe and mufflers are separate and easily removed without much clearance. |
(Post 1599571208)
I have after market CORSA mufflers and the over the axle pipe and mufflers are separate and easily removed without much clearance. So far I have the cats, mid pipe, tunnel plate out. Not a technically difficult job, just a lot to get out of the way to get to the clutch. |
Let me know how its going. I just got done doing my 05 ( ls 7 upgrade clutch) about a month ago. I'll be happy to give you any insight that hopefully will help if you want.
(Post 1599579050)
Getting the bell housing out was not too bad. Lowering the front subframe gave me enough room to get all the bolts out and then I was able to wiggle it out. Putting the bell housing back on was much easier as the LT1-S clutch is a good inch or more smaller in diameter. |
(Post 1599568697)
Only took the car for a quick drive just to make sure everything is working okay. My stock GS/LS7 clutch was definitely slipping and not holding the power from the E-force. This clutch holds it no problem. Before, the tires wouldn't break loose very easy and it just didn't feel like the car had the power it should; I suspected with the warmer temps my Super Sports were hooking up and the clutch was slipping. Now the clutch is holding great and the tires are easily breaking loose. Car is completely different now that the power is getting to the wheels. Definitely, a nice upgrade. |
(Post 1599591861)
Well, got the clutch installed and the car back together. Didn't have too much trouble other than getting the torque tube lined up and slid back in. That took me a few hours of fighting with it; it looked lined up but the front part of the shaft that goes into the pilot bearing just wasn't quite lined up. It finally popped into place.
So quick update. The rattling/chatter I thought was coming from the clutch actually is not. The clutch is completely silent. The sound I am hearing is gear rollover. Because the LT1-S uses a 1-piece flywheel instead of a 2-piece, drivetrain pulses from the engine idling are not dampened and these pulses are making it to the gears of the trans. This makes the gears twist back and forth making them tap against one another. Kind of sounds like marbles in a can. But this is completely normal. Verified by tech support at Monster.
Yeah, I was about to say... mine is nearly silent. It did get a little noisier once I added the cam for whatever reason, but it's a very quiet setup. Stock pedal feel/drivability, no issues. I am a fan of this line of clutches.
