1994-1995 AC decal
Anyone know where I can get a replacement AC Decal that goes on the blower fan housing?
I need a new one for 94-95 134a. I can't seem to find one in the usual Corvette parts websites. Thanks. |
Originally Posted by Subfixer
(Post 1599621122)
I need a new one for 94-95 134a. I can't seem to find one in the usual Corvette parts websites. Thanks. Have some one with any '94+ C4 confirm that # is on the label. Get a snapshot and have it duplicated or do one yourself on appropriate paper and put a clear acetate label over it. Shouldn't require much of an effort. Doesn't need to be a ZR-1. |
(Post 1599621122)
I need a new one for 94-95 134a. I can't seem to find one in the usual Corvette parts websites. Thanks. If above sticker is what you are looking for, I got it from Classic Industries - DC-1425. Lettering is a bit skinny and part number on bottom right is different. I am going to remove the original, try to restore the damaged left corner and see if it can be printed on sticky back film. Woops! I re-read your post. Looks like you are looking for a decal on HVAC fan housing. Sorry! |
Looks like above is what you are looking for. |
I’ve got the silver-black sticker just need to find it.
Originally Posted by secondchance
(Post 1599635419)
(Post 1599650562)
Yes, this is the one I need.
when I go to Carlisle late August I will check and see if any HVAC fan housing for sale has a clean sticker. If I see a good one, I am going to see if I can remove and reproduce. |
(Post 1599651684)
Sorry. I searched all over google and classic industry web site but no luck.
I have the original R12 decal on the '92, but since I'm switching to R134a, I want the correct label from 94-95.
I'm a little anal when it comes to stuff like that. |
(Post 1599656669)
I'm a little anal when it comes to stuff like that. So you need to have Yun or someone with a '94+ C4 to check that label and see if there is a number there!!! |
Originally Posted by WVZR-1
(Post 1599651830)
Lower right of the label I'd think there should be a part#. Either a match to the number I mentioned or something different. Did you look?
Radiator fan housing decals have different part numbers. Similar, not the same. I'll try to get the part number with a mirror or something. |
The overflow tank is very easy to move out of the way without hooking the lines. I would get a pic but I'm also an R12 converted to R134.
