Headers with Edelbrock E-force?
I have installed an Edelbrock E-force on my 2011 Grand Sport and have been enjoying it now that I have also installed a Monster LTS-1 clutch and it is holding the power.
I am completely stock other than the E-force. Thinking about some upgrades for next spring. Most likely headers, cam (LS9), and a tune. Because the E-force kit replaces the factory Z06/GS front mounted oil cooler with the LS9 diamond shaped oil cooler that is mounted on the side of the block, I am concerned that certain headers may not fit. Was thinking I might try a set of Stainless Works headers but not sure if I would have clearance issues. People with the E-force and headers could you chime in on what brand headers you have and if you have had any clearance or installation problems? Thanks. |
Get you a Dewitts radiator with the integral EOC. You have to remove the radiator to change the cam anyway. All you need to make it a bolt in affair is a couple of GM hoses for a Z51 Vette. These hoses run from the oil filter area to the radiator's EOC. You get rid of that oil cooler on the side of your block and you get a better/cooler running radiator. Your engine oil will get up to operating temp quicker too. It's really a great upgrade for a supercharged Grand Sport.
Originally Posted by old motorhead
(Post 1599636267)
Originally Posted by Spaceme1117
(Post 1599636339)
I did upgrade to a DeWitts when I did the E-force install. But I did not get the one with the integral EOC. But at the time, I was not thinking of any potential header clearance problems.
(Post 1599636434)
Well, shoot. If your current oil cooler is mounted like a ZR1, ZR1 headers should fit just fine. Just get the correct mid pipe to connect to your current axle back mufflers.
I have searched the forum trying to find this information but all the threads I am finding have Posters saying that headers fit fine on their car but they either don't specify if they have a manual car with the dry sump or if they have an auto. The autos E-force kits don't come with an auxillary cooler. |
