Michelin Pilot Sport A/S 3+ or Pilot Super Sport Tires????
Good morning,
Looking for some advise on which tires to go with on my Z06? The tires look to be very similar in the comparison chart listed below. I will not be tracking the car and will most likely only be putting 3 to 4 thousands miles on it a year. Thanks for the advise and looking forward to see what y'all have to say. https://www.michelinman.com/compare?...=&mode=vehicle |
One is a summer tire and the other is an all season tire. I guess it would all depend on what conditions will you most likely be driving. Wet, Temps below 40 etc...
I live in Georgia and don't plan on every getting the Z out in th rain unless by accident. Temps are typically above 40... :)
I have both tires on separate wheels. I use the MPSS tires for the track and the AS/3's for the street. The AS/3's are a better tire for street only and several folks I know with GS's and Z06's that are street-only have switched. The AS/3's are a little less $ and will probably last longer than the sticky MPSS's which will corner wear if alignment ins not correct. They will center wear quickly in the summer if inflation is not watched. AS/3's are a little more forgiving on thisBTW. The GM alignment spec is way too loose especially for toe settings. Insist on zero toe, not just meeting spec.
Originally Posted by zo6_ ruff
(Post 1599700036)
Originally Posted by Z06BOY-11
(Post 1599700154)
Well i live in GA and won't be driving the car in the rain unless i unfortunately get stuck in it by surprise. Other than that I doubt i will see to many temps below 40. Thanks
Dave |
(Post 1599700154)
Either tire will be great for street use. The AS3+ handles amazingly well for an AS tire. More than capable enough for the street. Both tires are going to age out before you can wear them out. Given your parameters, I'd go with the MPSS if only to get the slightly better sharpness in handling. I wouldn't sweat it if you end up occasionally driving <40 degrees either. Not like they are instantly going to turn into hockey pucks and crumble into dust. Just stay out of snow/ice.
I had the MPSS standard equipped z51. It sounded like a hailstorm of rocks hitting the lower fenders and rocker panels of the car. Chevy knows this happens and has put a thin film of clear wrap in those areas. I drove appx 2000 miles before buying the MPS A/S 3+ ZP tires. They have a less sticky tread compound and the ground hailstorm of rocks on body panels stopped. Sadly the clear plastic felt like razor stubble from the MPSS rock showers. I miss that car, but traded it for a new Z06 with skirts, and put MPS A/S 3+ ZP on the Z immediately.
Originally Posted by SilverGhost
(Post 1599710933)
So , I have to ask ... why were you driving around in sand :) Dave |
Originally Posted by Dcasole
(Post 1599711136)
It all just depends on what you want, maximum warm weather grip or not so maximum grip and an all around good tire ......
So , I have to ask ... why were you driving around in sand :) Dave I bought a Z06 Z07 with a halltech. Probably making 600/620. It came with new AS3+. I thought they would be garbage in comparison. I verified this with PDR "traction control active data". 80-90 degree ambient. 2nd geat 40 mph hit, zero wheel spin. Same for 50. Same for 30 mph. 1st gear at 30 mph has about 1 sec of traction control active but it's not enough to lose much speed. With that said. I'll never drive these on track but for a street car. I don't see why ANYONE would buy super sports over it. |
(Post 1599705023)
In that case I would go with the MPSS. I live in NC and temps are fairly similar. I am considering the AS3 only because I do occasionally drive in temps below 40 during the winter.
I purchased my 16 Stingray in Dec 18, which came with a set of MPSS tires. Temps in Md frequently drop below 40 deg, so I was able to break the rear end loose several times. This bothered me because my lady friend leaves for work before 6a, so it's always cold in the winter at that time of morning. Plus the low speed turn chattering was annoying. I changed over to a set of the AS3+ tires & haven't regretted the decision. The new tires are quieter, handle very well, will last longer, & are impervious to the cold temps here in Md.
While the car hasn't been driven yet in snow, it has been in numerous thunder storms, which it handled without any drama. I'm sold on these. |
Z06 w/ Z07 in the Atlanta area and switched to the A/S 3+ and they are a great tire.
Also in north GA. Ran the A/S 3s in winter / early spring. Switched back to MPSS for summer. Plan to do that going forward to get the most out of both sets.
I have set of Finspeed wheels with 19-20 OEM Z51 tires and another set 18-19" wheels with the old version Michelin A/S ZP tires, the ones with the big V tread.
The OEM Z51 tires are still very good shape so I've been putting off buying the new Michelin A/S 3 + ZP tires for the Finspeed wheels. I decided not to wait any longer and had a set of Michelin A/S 3 + ZP put on today ..... I am so Glad I didn't wait ! These tires are simply Great, ride better, quieter, and for an A/S tire, they have Excellent grip pushing it hard in Hot weather :auto: |
The a/s 3+ will give better tread life with acceptable grip in the dry. If you want to go with the summer only, the newly released 4s tire is better than the mpss and also has better tread life and acceptable wet performance.
