Muncie m-21 transmisson lever orientation
https://cimg3.ibsrv.net/gimg/www.cor...8eaf1bf4c.jpeg
Is this the correct orientation of the shift levers for a 66 M-21 close ratio Muncie Transmission ? I'm asking about the two levers that the shift rods connect to. The levers have a bend in them and I'm not sure if I have them placed correctly. Thanks, DFA |
Threads on the rod look awfully close to the end, but I think the orientation of the levers is correctl
https://cimg9.ibsrv.net/gimg/www.cor...2f33f4d448.jpg |
65GGvert,
Thanks for the picture. It looks to me that my 3rd to 4th lever is reversed from yours. By that I mean mine is bent away from the tranny and yours is bent towards the tranny. This would also explain why the threads are so close to the end of the rod. Is this what you see also ? Thanks, DFA |
Also looks like you have (or did have) a pretty decent oil leak..
To stir the pot (in a nice way, I hope), this subject has been a little controversial in the past. The AIM and service manuals pretty clearly show the 1-2 lever (rear) with the offset towards the transmission, and the 3-4 lever (front) with the offset towards the tunnel wall. JohnZ supported this configuration in an old post from 2010. https://www.corvetteforum.com/forums...-question.html
With that said, the 1965 St. Louis picture at body drop that has been floating around pretty clearing shows both levers with the offset towards the transmission. I personally run mine with both offsets toward the transmission and have found no interference through the full shift pattern. My recommendation would be to do the same. Pic from AIM's https://cimg2.ibsrv.net/gimg/www.cor...7bd35fdd7c.jpg Pic from Service Manual https://cimg9.ibsrv.net/gimg/www.cor...d53002f765.jpg Body drop pic from St. Louis 1965 https://cimg9.ibsrv.net/gimg/www.cor...080c2816eb.jpg |
I should have added the exception to actual assembly pictures was the unique '63 shifter with the crossed shift rods. The 3-4 lever was clearly assembled with the offset outward toward the tunnel wall.
AIM pic https://cimg5.ibsrv.net/gimg/www.cor...1c06c7a4ed.jpg Pic of '63 Fuelie from JohnZ presentation https://cimg2.ibsrv.net/gimg/www.cor...7742b4e6d0.jpg |
Originally Posted by DFA
(Post 1599731692)
65GGvert,
My experience has been that when in neutral both 1/2 and 3/4 levers are almost vertical.
Originally Posted by 65GGvert
(Post 1599733216)
https://cimg9.ibsrv.net/gimg/www.cor...5caf6d186b.jpg |
Originally Posted by Frankie the Fink
(Post 1599732014)
DFA |
Originally Posted by Mike67nv
(Post 1599733467)
On a '67 at least, the levers actually slant slightly toward the rear when both are in neutral. If the 3-4 lever were reversed (offset outward), it would slant slightly forward and require a longer adjustment on the rod like the OP was showing in his first post.
https://cimg9.ibsrv.net/gimg/www.cor...5caf6d186b.jpg Mike, Is it OK if I save this picture to my file? |
I installed my 3-4 rod as shown in this picture and the rod end hit the tunnel at the shifter. Had to turn it around and place the adjustment at the Tran end.
Here's another picture I have on file from a previous thread, not sure who's picture, but it shows a pretty clear view:
https://cimg0.ibsrv.net/gimg/www.cor...0b8622a8e2.jpg |
Originally Posted by DZAUTO
(Post 1599735253)
Mike,
