Doing my headlight lenses
Suck,suck,suck,suck..... motherf$@#*&...........................
OK now that I got that out of my system, I broke some pieces off taking apart my first headlight. Am I alone in this? Somehow I don't think so. The black seal areound the lens came out fairly easy. Once I got it started with a small screwdriver it pulled out in a couple of long pieces. Wil crazy :willy: glue work on these pieces? https://cimg1.ibsrv.net/gimg/www.cor...f575ff8b55.jpg https://cimg2.ibsrv.net/gimg/www.cor...64bc3c0c1e.jpg |
ouch
That does suck. I would JB weld them. Stuff works great.
https://aescorvetteparts.com/collections/corvette-c6
Also check these guys out, I have bought stuff off of them, they are a vendor here on the forum. |
Originally Posted by ls1121
(Post 1599738711)
Get some of the 2 part epoxy made for plastic, this stuff is great , it has a liquid for one side and a felt tip pen with hardener for the other side... Once you put the 2 halfs together they're not coming apart, and if it breaks again it won't be in the same spot., Trust Me on this..WW
Thanx guys :thumbs: I will get some and reattach this one piece.
Agree with the 2 part epoxy, I had the same problem, I would rather change the transmission then do the headlights again. BUT it’s worth it when it’s done..
Yea, I got my kit and need to do it. How long should I allow for it? It is my only vehicle, so i will need to start and finish it with no hiccups.
Originally Posted by subfloor@centurytrans
(Post 1599738912)
Not sure where the bigger piece came from, but I wouldn't worry about the smaller piece with the Torx stud. I broke 5 of mine off when separating them but the headlights stayed together just fine as the new glue is REALLY strong.
(Post 1599747597)
So what glue did you use to attach the lens? In a video that I had watched the adhesive was a beige color, is there any black adhesive?
https://cimg2.ibsrv.net/gimg/www.cor...4863fcdea6.jpg |
