GSpeed Motec M150 Race car engine harness
Our next motec project after our C6 plug and play was a complete stand alone engine harness. This allows you to build a race car using aftermarket ABS, Aftermarket gauge cluster, and your own wiring for switches. The largest issue when building a true, non oem race car can sometimes be the wiring. At GSpeed, we build a LOT of race cars, and waiting on these custom bits, even when made in house, can be a show stopper, and add months to your build time. After wiring several race cars, we took the best design, and have decided to build them to keep in stock. These are on the shelf, and in the case of an out of stock situation, only 4 weeks to build.
The key components to this system are:
https://cimg8.ibsrv.net/gimg/www.cor...eead36db4c.jpg https://cimg0.ibsrv.net/gimg/www.cor...7663a76921.jpg https://cimg4.ibsrv.net/gimg/www.cor...f6ed68e5ad.png https://cimg0.ibsrv.net/gimg/www.cor...fcba3c61f0.jpg https://cimg8.ibsrv.net/gimg/www.cor...a4fb2c5bcb.jpg Feel free to ask any questions! As we solve and work through problems on these cars as we turn them into race cars, we make those parts available to anyone. |
Any new price
Digging up old threads, is this product still available?
Originally Posted by 383 Z06
(Post 1606092793)
yes, please call. Very application specific. 877-512-5180 MoTeC ECUs are slow to deliver at the moment, but stock should be back in lock step by early summer. |
I have a manual C7, would this harness work?
Originally Posted by Operations
(Post 1606112739)
The C7 we are building has this harness, but its port injection, and we switched the sensors over to LS configuration. it also has no VVT or Variable oil pump (Dailey drysump) so its not fair to say that itll "work" on the C7 with out some changes. |
Mine has a Katech 427 from a LT1, pretty sure the vvt is gone, has ARE dry sump tank, will check hack later
