ZR1 owners, this mod is for you. Check it out.
Hello, Everyone. We are glad to announce that our 95 mm (LT5/ZR1) throttle body is now available. Please visit our store. Here are a few highlights and pictures. We also have a throttle controller to spice it up even more. Thanks.
FEATURES: • Optimized Active Contours (Both Upstream & Downstream) • Porting Taper and Upstream Bore (Lip & Bore Reduction) • Greater Discharge Coefficient of Plate/Blade • 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction) • Shaftless High-Pressure side for Larger WOT Flow Area (100 mm Effective Bore) • Self-Cleaning Throat/Flow Gap • Dome head CRES screws, thread locked • Made from Brand New OEM Parts BENEFITS: • Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience • Linearization and smoothing of the curve for a more predictable response and crisper shifts • Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble) • Eliminate the need for ECM tuning (LT5 only, LT1/LT4 may require tuning) • More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications • Easy Installation (15 Minutes or Less) https://cimg6.ibsrv.net/gimg/www.cor...e55da3efcd.jpg https://cimg7.ibsrv.net/gimg/www.cor...6753679dc2.jpg https://cimg8.ibsrv.net/gimg/www.cor...574af01208.jpg https://cimg0.ibsrv.net/gimg/www.cor...0606cf2883.jpg https://cimg1.ibsrv.net/gimg/www.cor...240dea217a.jpg https://cimg2.ibsrv.net/gimg/www.cor...f463293d72.jpg https://cimg3.ibsrv.net/gimg/www.cor...b6b6bc3ad9.jpg |
Throttle body
What cars has it been texted on? What were the HP results?
What is the price of this unit? where are you located? How many have you sold? Who are your satisfied customers? Any dyno charts ? NW |
Prices are on the web site in his sig. Nice looking t-body, but I just put one on. Not sure if you own a ZR1 or not, but there is No Hesitation and No Stumbling, my Z06's yes for sure, you needed a ported t-body to get the car to run right, this engine is different, it ran really good with the stock t-body, but even better with a ported one. :)
Originally Posted by NinjaZX14r
(Post 1600139143)
What is the price of this unit? where are you located? How many have you sold? Who are your satisfied customers? Any dyno charts ? NW We are in the AL Mobile Bay area. We have sold hundreds of LT1/LT4 TB's, the LT5's just came out, so, not many. Our customers are mainly from this forum, Camaro 6 forums, and CTS-V forum. Many threads and reviews here, in fact, most of the discussion is here too. Everything started here in this forum. No dyno charts yet. Although this TB modification was designed to work for the ZR1 with the stock tune, it is mostly used by LT1 supercharged and modified LT4's. The test cars happen to be heavily modified and it would be hard to compare apples to apples. I'd add that looking at WOT dyno charts would be very misleading, as it would not catch the main benefits of the TB. Yes, you'd have a more streamlined TB with a larger flow area and it should yield a moderate gain at WOT, but that is just gravy. The meat is at low to part throttle. There is much more info in our website technical page (https://www.solerengineering.com/technical). Thanks, |
Do you offer credit for the return of the existing core (95mm) ?
Perfect, just placed the order. I have been waiting for this for quite some time now. I am glad it’s finally available for LT5. :cheers:
Interesting. That was the most technical write up about a throttle body I’ve ever read.
Hell I’m sold. Let me get past my first 1000 miles and then I’ll pull the trigger. Is there any kind of horsepower gain number to put out there? |
Warranty voided with this mod?
Originally Posted by robmypro
(Post 1600144308)
How does this compare to Nick Williams 103mm TB?
Originally Posted by Repo Pilot
(Post 1600140409)
Originally Posted by TheRobSJ
(Post 1600143478)
(Post 1600144308)
Originally Posted by AD2386
(Post 1600144805)
Originally Posted by AD2386 https://www.corvetteforum.com/forums...s/viewpost.gif How does this compare to Nick Williams 103mm TB?
Originally Posted by Mike@SolerEngr
(Post 1600145133)
Great question. I'll have to do my homework in that regard, but I would not publish a direct brand comparison, at least not publicly. I think only customers can openly tell and hopefully some folks will chime in at some point.
Thanks... |
Any new installs and opinions?
I replaced my ported TB with Soler this weekend. What a beauty. So far so good...
https://cimg3.ibsrv.net/gimg/www.cor...7cecdb4ab.jpeg https://cimg4.ibsrv.net/gimg/www.cor...8a8b5a9a8.jpeg |
Hello everyone,
I've been a member of the forum since I picked up my first Corvette (a C6) back in 2005. Since then, I have gone through a few other Corvettes along the way which included a 2014 C7 Z51 which was then traded in for a 2015 Z06/Z07. I kept the Z06/Z07 until last month when I decided to pull the trigger on a Sebring Orange ZR1 A8 with the ZTK package. I've owned several other sports cars in my time including a few exotics and I have to admit the sluggish pedal response in all my Corvettes has driven me crazy. I've never made any modifications to any of my cars but after reading through several posts here and reading about other forum members commenting on their ported throttle body upgrades, I decided to go for it. I probably read through every post I could find on the topic and came across Soler. Seeing that I'm not mechanically inclined (Let's be totally honest here... I know how to put gas in a car and start it) I passed the link to Soler's website on to my brother who is an engineer. BIG MISTAKE!!! If any of you are related to an engineer, you know what I'm talking about. You can ask my brother for a light bulb to replace one that has burned out and he will have to go through the history of how it's made and how it works before handing it to you. Anyway, after going through the detailed information Mike has posted on his site, my brother was very impressed and gave his thumbs up on the purchase. I reached out to Mike with a few questions since I didn't see one for the LT5 . He explained that they were in the final stages of testing one and offered to get me one ASAP. I must say, his customer service is impeccable. After about a week, he reached back to me saying the LT5 TB was ready . We traded a few emails back and forth and he detailed what to expect and offered his assistance if I ran into any issues with the install. I received the LT5 TB a few days later and installed it that Sunday. We followed the instructions to a T and the whole process took about an hour and a half to install the TB and a CAI on the car. More specific, it took about 15 minutes to install the TB and the rest of the time was spent wrestling with the CAI and throwing some choice words around the garage associated with that install. After we put everything back together, we ran through the learning instructions step by step. We followed the disconnect battery overnight instructions and ran through about six steps before taking it out on the street. I have to say, the pedal response on the ZR1 was much better than my Z06, but with the Soler TB installed, it is absolutely perfect. Response is immediate and shifting is very crisp. The best part is that it doesn't require a tune and you would never know it was changed out looking under the hood. Seeing the opportunity to add another car to the stable and drive my wife crazy, I came across a deal a week later on a 2019 Camaro ZL1 with the LT4 engine with only 3,100 miles. I couldn't pass it up and had to upgrade that TB too. I placed the order with Soler and received it two days later. Again, after following the overnight instructions with disconnecting the battery, I installed it within 20 minutes was was out on the road within the next 30 enjoying the upgrade. It was like night and day with the LT4. I wish I had done my homework sooner and upgraded my Z06 with a Soler TB. Anyone looking to upgrade their TB either for their Corvette or Camaro, I highly recommend Soler. They are top notch in every aspect and you won't be disappointed. On a side note, Mike sent me a little goodie to test out on the ZR1. Unfortunately, I haven't had time to install it yet. I've been too busy with work, but as soon as I can get back in the garage and get it installed, I will report back on my thoughts. |
Crossed my 1000 mile mark this week. Pulled the trigger. Can’t wait to install it!
(Post 1600212430)
