I need help
I have a 2016 Stingray.The right door will unlock when I approach my car.The left door will not unlock. I have to use my transmitter.I have read the owners manual and I tried every thing in it. Can anybody please give my some help? Thanks,Rod
Hey Rod,
See if this works, on your infotainment settings select all doors for passive door unlock. Odd that it’s your left door that doesn’t unlock tho... :thumbs: Passive Door UnlockThis allows the selection of what doors will unlock when using the door handle sensor on the driver door to unlock the vehicle.Select All Doors or Driver Door. |
Originally Posted by ROD BROWN
(Post 1600825291)
He obviously has it on if the right door is unlocking while approaching the car.
Originally Posted by R8Z51
(Post 1600825401)
Sounds like the touch pad on the driver's side is not working properly. They aren't expensive and it takes <15 minutes to swap out the pad.
To be sure, when you pull on the driver's pad to open the door, nothing happens? Correct? When you do that to the passenger door and/or the trunk/hatch both open? Elmer |
Originally Posted by eboggs_jkvl
(Post 1600825408)
Drivers door
Your fob battery may be getting weak. Change it and see if it solves the problem.
(Post 1600825433)
Just the passenger door works correctly.Doesn't affect the trunk.
(Post 1600825458)
Drivers door
OK, getting confused in Florida. Change the FOB batteries and give it a whirl again on the door opening adventure. Elmer |
I can't remember the EXACT procedure but I had a similar issue with my previous car (C6) I removed the door pad and cleaned everything I could find and that fixed the issue.
Originally Posted by shakinrock
(Post 1600826093)
Elmer |
If you need to "clean" your door contacts - here is how. I know the video is for a C6 - but its the exact same procedure for a C7:
Found the problem
Found the problem guys.The wire to the antenna fell off.The wire was loose and wasn't making contact.The tech. tightened the end of the wire so it won't ever fall off again.He wrapped a piece of tape over the connector and I am back in business. Thanks to all who replied to my problem. Rod
Which antenna?...there are 6 for the Keyless Entry System.
Antenna
Originally Posted by ersatz928
(Post 1600838315)
(Post 1600840691)
The Tech wrote on the repair sheet it is the Keyless entry module Antenna 1.Thats all I know.Rod
Finally got it
[QUOTE=Silver C7;1600850488]I remember your "Victim Of The Strike" thread...Did you ever get that car back or is this a new
I finally got my car back on the 17th of this month. It was a long wait.This is a new thread. Thhe tech found the loose wire and slipped on to the connector.As soon as he installed the wire the door worked..I am happy.It was a long wait.Sept. 17th to Jan. 17th.It was one long walk every day. Thanks to all who gave me a lift when I was in need.Rod |
all my doors and the trunk is unlocked !!!! check the owner's manual or a YouTube video !!!!
Originally Posted by wgood
(Post 1600876104)
