Gbcb2468 |
08-02-2021 06:12 PM |
Oil pressure gauge reading zero
Got an interesting one here. I disconnected negative side of battery in order to remove airbag for steering wheel swap. Got the swap done, no issues and reconnected negative side. I pushed start button to green and didn’t try to start. Gauges swept to right then left and I confirmed no airbag light. I started car and noticed I didn’t have any oil pressure on gauge and xxxx for oil pressure in message center. Coincidence or did oil pressure sensor decide to go after battery reconnect? I confirmed oil movement in valve cover. 2008 C6 Z51base 6M
