FS Cross bar for five point harnesses
I bought this R&D Cross bar on here awhile back and paid 300 IIRC. I didn't use it and should let it go for someone else to use. 300 Shipped,
https://cimg9.ibsrv.net/gimg/www.cor...87428bebf5.jpg I would prefer Venmo but check paypay etc work too. |
What year and body type does it fit?
That's a good question. I had it for my '88 and can do some research about it fitting later years.
I'll take it.
PM inbound to finalize. I just picked up the camber-bar they did also, now can be matchy-matchy with both, thanks! |
Got your PM writing you back to be sure.
PM sent. I read the bar fits 84-90E and a different bar fits 90L-96 but I can't find anything on the differences.
Here's the picture I saw of one installed in a 91+ if that helps, maybe the end link or bar span is different?
https://www.corvetteforum.com/forums...tructions.html So I'll back off then so someone with 84-90 can buy if this matches that application. thanks! |
I'll take some pix with a tape measure across the mounting points in a few min.
These help any? First is total length then the flanges.
https://cimg7.ibsrv.net/gimg/www.cor...e9498ef81e.jpg https://cimg9.ibsrv.net/gimg/www.cor...493dd3fb98.jpg https://cimg1.ibsrv.net/gimg/www.cor...2e739de2c4.jpg |
on my '93
- 48" should be fine for bar width - its approximately 12" distance from seat belt mount on integrated roll bar (top) to targa bracket on floor (bottom) hole is so without enlisting my son to do the trigonometry to convert 4" and 9" and 1" bar (?) to see if + 12", my 'guess' would be the bar and more complicated roll bar (top) bracket are same both years, and the bottom simpler strap was probably adjusted slightly different length or bends or both for any difference in height or mounting position of targa bracket? So might be perfect fit or might need slight adjustment / fabrication on the lower strap/bar, is again my guess. But probably also only coupe, convertable way different top belt bracket? Since Kevova asked first I'll defer to him if he wants it. If Kevova doesn't want it I'll take it. Cheers |
I'll be passing it's all yours
Originally Posted by Kevova
(Post 1605453696)
Will complete via PM |
Okay thanks guys! Checking PM.
