Done PCV MOD....Couple Concerns + Pics
Finished the PCV Mod didnt take long...had a little difficulty deciding which hose it was but nevrenuf helped me out :cheers: .
Here are pics of the install. https://pic1.picturetrail.com/VOL111...0/18633866.jpg Had to show a pic of the dog :D https://pic1.picturetrail.com/VOL111...0/18633860.jpg Materials used https://pic1.picturetrail.com/VOL111...0/18633854.jpg High Temp Silicone used on bottom of filter https://pic1.picturetrail.com/VOL111...0/18633850.jpg Had to cut a bigger piece of hose so it would fit better. Home depot only had this red high pressure hose...I got a black one from another store but was too big. https://pic1.picturetrail.com/VOL111...0/18633832.jpg Red hose into the intake https://pic1.picturetrail.com/VOL111...0/18633820.jpg Finished product :hurray: :hurray: https://pic1.picturetrail.com/VOL111...0/18633809.jpg Close up of the filter...arrow on filter facing toward the intake manifold. K...havent turned on the car or anything because Im still doing a couple more mods so wont be firing her up for a week or so. My concerns...what if that filter housing hits the belt? Is there something I could have done to install it better...I couldnt curve the original hose enough to the left because of the actual wire that was clamped onto a metal piece on the hose. Either way...easy mod...hope everything was fine...please let me know...and definitely need to thank benelliwang for his website instructions :thumbs: Thanks |
Re: Done PCV MOD....Couple Concerns + Pics (USMUSCL)
What, no MGD??? :nono:
Re: Done PCV MOD....Couple Concerns + Pics (benelliwang)
What, no MGD??? :nono: I forgot the main part of the install :nonod: :nonod: :sad: Can I ever be forgiven?? [Modified by USMUSCL, 10:32 PM 1/17/2003] |
ttt
Sorry I can't help you ... but I think that you could tie down the lines to prevent the filter from moving if possible ..
I used a couple of tie wraps on the hose to secure everything. :cheers:
Re: Done PCV MOD....Couple Concerns + Pics (bgood)
Could the red hoses be shorter? Just wondering if that would help.
Re: Done PCV MOD....Couple Concerns + Pics (Viprklr)
I'd put the filter closer to the intake end of the hose and use ty-wraps and maybe shorten the hose.
You want the drain pointing down , not at an angle. :cheers: |
I installed mine very similiar to yours except I have the filter about 6-8 inches
from where yours is ( basically right by the radiator ) ...just was thinking you want this to hang down vertical and at the farthest point away from engine heat & belts...oh yeh...use a few more cable ties but make it accessible to empty the oil out.. :cheers: |
http://www.shutterfly.com/osi.jsp?i=...21b33396ccc48d
Go to this link and scroll through the slide show. You'll find pictures of my install. |
Re: Done PCV MOD....Couple Concerns + Pics (jfpilla)
http://www.shutterfly.com/osi.jsp?i=...21b33396ccc48d Go to this link and scroll through the slide show. You'll find pictures of my install. |
I used a couple of tie wraps on the hose to secure everything. :cheers: I did this as well. Steve |
just how much does this set-up trap ?
Re: Done PCV MOD....Couple Concerns + Pics (MRWHOOPPEE)
I installed it about 2000 miles ago. So far I've had about 1/8" of oil and that was right after an oil change. Since then, none. I've read the later years have fixed the problem. It was cheap, easy and fun. Probably the main reasoning for doing it. But, any amount of oil through the intake is too much for me. :leaving:
It looks like you used an excessive amount of hose. Here's a few pics that I took of my install. I moved a few things around, but you should get the idea of the orientation from my pics. I'm sure the mod will work regardless of the amount of hose used, but I'd think it would be best to use as little hose as possible so that you don't run into heat issues with the added hose laying around or that it doesn't get caught up in anything. YMMV, but this worked for me:
HTH! http://www.whitneyroberts.com/images...od/pcvmod1.jpg http://www.whitneyroberts.com/images...od/pcvmod2.jpg :cheers: |
Re: Done PCV MOD....Couple Concerns + Pics (AllCammedUp)
Anybody have a shopping list for these parts? What's the diameter of the hoses being used? Do you leave the drainage capability intact to remove any oil caught by the filter?
Looks like a get mod!! :lurk: http://us.f1.yahoofs.com/users/26641...FKiK.AFjLaHNM0 [Modified by dads01dream, 11:25 PM 1/18/2003] |
Re: Done PCV MOD....Couple Concerns + Pics (dads01dream)
Anybody have a shopping list for these parts? What's the diameter of the hoses being used? Do you leave the drainage capability intact to remove any oil caught by the filter? Looks like a get mod!! :lurk: http://us.f1.yahoofs.com/users/26641...FKiK.AFjLaHNM0 [Modified by dads01dream, 11:25 PM 1/18/2003] Moderators, anyway we can put this in link in the tip/DIY/links sections? We seem to get this request everyday... USMUSCL, you hose is too long, cut them short and it won't be too close to the moving parts. Notice my setup is way back and away from all the moving parts? |
Great write-up!! Two mo' Q's for U.....
1. What's the diameter of the oil hose? 2. Wy not leave the drainage fuctional, wouldn't this help to get rid of the oil collected? Thx! |
Great write-up!! Two mo' Q's for U..... 1. What's the diameter of the oil hose? 2. Wy not leave the drainage fuctional, wouldn't this help to get rid of the oil collected? Thx! |
