Soler TB
Hi everyone, i will start by thanking all that respond to this thread. I went to the Bash in BG and was talking about the Soler TB , had mixed reactions some said it was not a proven product yet. This will be installed on a ZO6 any and all input is appreciated.......Thank you
Not proven? It was proven a decade+ ago on the GM GenV V8 platform... I ran multiple variations on my C7 and have one on my C8 as well.
He sells a specific paired set for the C8 Z06: https://www.solerengineering.com/gen...ors/se3793-040 |
What Kracka said
What the 2 above said !!!
+1.
Yes for sure Kracka's advice.
The only thing I would add to the Soler TB would be to also add the Solar Throttle Controller. I did both at the same time, these two items really match up well together. The Throttle is not lively whatsoever on the C8. Not sure if it's the same on the Z. The Soler TC is very popular with the SR owners. |
Originally Posted by ArizonaZ06
(Post 1607776842)
Originally Posted by AEST BOSS
(Post 1607778042)
Did it throw any codes from the TB swap?
I kept getting abnormal response TPS sensor CELs when running the Soler Ported TB (91 mm eff) on my 2022 C8 3LT.
It would come on here and there , then go off but remain constantly set whenever I scanned the OBD of the car. Yes I would do the so-called 'relearn' procedure multiple times and pull the battery, code would still set (however without illuminating the CEL itself so I could live with it) I ran the PTB for around a year but recently got a new CEL for 'clutch 1 pressure' (dreaded DCT code) so I decided to remove it so as to take out one way GM could deny service. Once I pulled off the PTB and went back to stock the CEL for both the DCT AND the TPS sensor code went away even when scanning. Surprisingly the car actually drives a little better IMO with the stock TB , smoother and less jerky on the partial light throttle compared to the 91 mm ported unit. I'm gonna sell the Soler and just stick to the stock one at this point. As they say , YMMV ... but I know since were all desperate for SOME return on these useless mods (well useless on a relatively stock C8 stingray :rofl:) someone will argue with me , however I'm of the school of "if it makes you feel better running it enjoy" ;) |
(Post 1607778042)
About 1 year later sold my Hydro painted engine cover and the Gwatney for the Lingelfelter pTR manifold. The LT5/ZR1 TB matches the pTR. My recent E85 tune with mods brought out the C8 RHP. |
(Post 1607781981)
Never had a CEL with the TB swap. Mike from Soler help me based upon my current ported Gwatney manifold. TB recommendation was the LT5/ZR1 and he suggested including at the time the wired 2001 Soler Throttle Controller for a mere $100. Have this TC still today and is one of my best mods.
Just got this quote last week in south FLA. About $3,250 to unlock the ECU, tune it, and then add the E85 turning.
https://cimg8.ibsrv.net/gimg/www.cor...7cc578ad56.jpg |
Originally Posted by Zse4%rdxCft6
(Post 1607782286)
I have a Lingenfelter 95mm w/ PTE intake. I've had the TPS light many times. Only at the track. I'm sure its related to the multiple inputs over a span and the design. It was every other session oddly. LF told me they had ran into this with several cars they tracked also. They told me to flip the throttle body 180. I did and that solved that for a year.. Not sure the reasoning. But it started back after a heads cam build. But under the knife again and will be looking into a lot. Also not sure if the angle of the PTR intake neck is a possible consideration.
Originally Posted by NoMatter
(Post 1607785106)
They told me to flip the throttle body 180. I did and that solved that for a year. Also not sure if the angle of the PTR intake neck is a possible consideration.
We’re going to be looking into it a little during tuning. The video I saw of Lingenfelter’s new 427 looked to have a Nick Williams TB. It was solid black and billet. It was also turned 180° from OEM. What you’re saying seems just right. Who knows what other variables there may be. https://cimg9.ibsrv.net/gimg/www.cor...aad129d33.jpeg |
Originally Posted by jpmotorsport
(Post 1607781932)
That sounds like an install issue. You could have sent the TB back to be replaced by Soler Performance.......wonderful company. So why are you selling when you are admitting there was an issue, sir?
