Replace the power brake booster?
I have a hiss when I apply the brakes and I have to stand on them to stop. Since the brakes still work and no leaks I assume this is a booster only that needs replaced. Has anyone done this? How long should it take? Do I have to take out the dash? Any experiance is greatly appreciated.
Re: Replace the power brake booster? (mogulmike)
Sounds like your booster is gone. I did this several months ago. Took about 4 hours. Hardest part was getting to the nuts up under the dash that hold the booster on. The shop manual outlines the procedure real well. I had to buy the replacement booster from Chevrolet (couldn't find one aftermarket). I got mine for aboput $260. new. IM me if you need help.
I bought mine for $106!!! Check CSK on the web--they still have them but THEY HAVE JUST NOW GONE OUT OF PRODUCTION!!! Get 'em while they're hot...er...cheap!
Re: Replace the power brake booster? (C-4 Cross Fire)
Just did mine. Got it from advance Auto for $ 98 with lifetime warranty. It's metal so maybe it will handle the heat from my headers better. If you are of large proportion like myself, do youself a favor and take the seat out. Also, make sure you have 1/4" extensions.
Yup, undoubtedly a brake booster. :yesnod:
If it gets worse, it can stall your engine upon hitting the brakes. How'd you like to have no power brakes AND no power steering! :eek: |
I have a hiss when I apply the brakes and I have to stand on them to stop. Since the brakes still work and no leaks I assume this is a booster only that needs replaced. Has anyone done this? How long should it take? Do I have to take out the dash? Any experiance is greatly appreciated. |
That's it! I am blaming you guys. I never even heard of a power brake booster and now I think I caught the disease from this post. Last night when I got in the car and started it, I heard a hiss. Sounds like air escaping under the dash and the pedal gradually sinks as air escapes? Is that the PBB? I had my master cylinder replaced about 6 mos ago. Damn. And they say vettes are inanimate...
Ordered my booster last night from andvanced auto for $98. If I just take the plastic cover of the under dash will I be able to get to everything ok or do I need to take out my instrument cluster also? My buddy has my book "somewhere in his garage" so any tricks would be greatly appreciated.
When you all say hiss, is it occurring when you let off the brake pedal and its more like a sucking sound? My brakes seem to work fine but every so often I hear a hissing or sucking sound as I release the pedal. Wondering if I should order the parts now antisipating this to be the next item on the list.
Yea, on my list, hard peddle, but no sounds yet, so better order one now and do it....
Re: Replace the power brake booster? (jerkyboy)
Do you have the web add for advance auto...?
Re: Replace the power brake booster? (vinnies87)
The cluster does not have to come out, only the composition hush panel. The trick is getting to the nuts which hold the booster. I found it much quicker to take the seat out to give me enough room. Extensions are a must as is a good light source. Not a hard job just a PITA.
:iagree: or a Cirqu de Solile performer....(spelling de jour) thats french.
Re: Replace the power brake booster? (93JetJocky)
My hiss is a sucking sound but only heard while the brake pedel is pushed so while sitting at a red light the sound is constant. If I push the pedal to the floor the noise goes away. I assume the hiss is a break in the vaccum and since I have to remove the "hush panel" is why it is only heard inside.
Re: Replace the power brake booster? (Southern Comfort)
After donating some blood to the underdash area, I found an extension at Sears the is like a spring. Once I hooked that up, the underdash nuts were a 5 minute job. Pays to have the right tools!!
I went to AutoZone last night to order the BB and their suppliers are both out. I then went to O'Reilly and the price matched Autozone. Both have lifetime guarantees. If I can get someone to post pics after I get done, I will try to take pics while I do the job this weekend.
