Knock sensor question
Will a knock sensor for an '89 corvette work with an '86? Thanks. :cheers:
Re: Knock sensor question (NUckINg FuTS)
I dont know if it will work but it is a different P/N. 84-86 use the same sensor and 87-89 use the same one. Just for added info 90-91 use the same then 92-95
You may want to update the ESC module. Part #'s are in this post:
http://forums.corvetteforum.com/zerothread?id=155665 |
Will a knock sensor for an '89 corvette work with an '86? Thanks. :cheers: I haven't had a chance to do any WOT blasts to see what difference it makes, but I didn't get any code. Jake |
