Gas Pedal tension - is it adjustable?
Anyone who drives another car besides their C5 everyday has probably noticed how the gas pedal on C5s are really hard to push relative to other cars, plus you gotta lean on it pretty hard before it will really start to move. I've got a A4 and was wondering if there is anyway to make the gas pedal feel "lighter". I'm tired of my right leg getting a full work-out on hour long drives. Can the pedeals tension be changed, or am I going to have to just live with it? Any help is appreciated.....
Re: Gas Pedal tension - is it adjustable? (aggie03)
get lead shoes
Are you serious? The C5's gas pedal is the lightest pedal of any car I've ever driven. There's not even a linkage attached to it. My Camaro's gas pedal is a million times harder to push, but is by no means difficult. Is your gas pedal jammed or something? Maybe the hinge is busted?
The only thing that provides tension on the gas pedal is a spring that's behind it. If you don't actually have a problem, replace the spring with a lighter one? Personally I've been looking into putting a heavier spring on mine. The gas is so light that it's touchy for me. Dope |
Re: Gas Pedal tension - is it adjustable? (Dope)
________________________________________ ________________________
The only thing that provides tension on the gas pedal is a spring that's behind it. If you don't actually have a problem, replace the spring with a lighter one? Personally I've been looking into putting a heavier spring on mine. The gas is so light that it's touchy for me. Dope[/QUOTE] ________________________________________ ________________________ I replaced the spring behind the gas pedal with a heavier one. My ankle was killing me tring to keep pressure "off" the pedal. I went to a Hardware Store and bought a heavier spring and cut it down to size. Much...Much....better |
Anyone who drives another car besides their C5 everyday has probably noticed how the gas pedal on C5s are really hard to push relative to other cars, Thanks Dennis |
Re: Gas Pedal tension - is it adjustable? (Droberts)
If you want a stiff gas pedal, go drive a 90-93 Chevy suburban or pickup. Those suckers are stiff.
Re: Gas Pedal tension - is it adjustable? (6SPD98)
________________________________________ ________________________ The only thing that provides tension on the gas pedal is a spring that's behind it. If you don't actually have a problem, replace the spring with a lighter one? Personally I've been looking into putting a heavier spring on mine. The gas is so light that it's touchy for me. Dope ________________________________________ ________________________ I replaced the spring behind the gas pedal with a heavier one. My ankle was killing me tring to keep pressure "off" the pedal. I went to a Hardware Store and bought a heavier spring and cut it down to size. Much...Much....better I wonder if different years had different gas pedal springs? My gas pedal is like playing a video game, it really is. I have a set of pedals + wheel for my computer and the gas pedal has similar effort (ie: no effort). Dope Dope |
Re: Gas Pedal tension - is it adjustable? ( )
guess your car is not a m6 then.
Dope, I wish I could trade you the accelerator pedal bracket in my 99 A4 for yours, LOL. It is so stiff that my right shin gets fatigued after a few minutes. Also, the stiff pedal makes it hard to get the amount of part throttle that I want. I think there must be different springs that were used.
Aggie, please let me know if you find out anything about loosening it up. Anyone know how to change the springs:confused: Dennis |
Aggie, please let me know if you find out anything about loosening it up. Anyone know how to change the springs:confused: ________________________________________ ________________________ I believe I used a screw driver to pry the spring loose. I went to an "Ace" hardware store. It was an old style store that carried a little bit of everything. They had a great assortment of springs. I found a heavier one, I just had to cut it down to size. My car as you can tell from my signeture is a 98 six speed. My pedal was very, very light. It was the lightest gas pedal I ever came across. |
I'll trade one of you A4 guys :)
Hmph, wonder why on earth the A4 would be heavier. That's wacked. Dope |
Droberts, mine is also a 1999 A4 so I'm wondering if the hard pedal is exclusive to that year and automatics. The forum seems divided on whether their pedal is hard to push or not. I'm telling you, mine is not stuck but it is hard as hell to push, and on long hwy driving when you let off the gas a little and then want to resume your original speed it takes more force than any other car I have ever owned. I should mention I'm only 23 and my right leg actually feels worn down after my hour commute to and from work every day. I'm going to look behind the pedal and see if I can remove the spring or replace it with a lighter one.
Aggie, the gas pedal is attached to a bracket that has the springs inside of it. You must take the bracket out and try to remove the springs. Send me an email and I can send you a pic from the Service Manual CD.
Dennis |
