Ok, I have found a set of 1.6 rockers from an LT4 with 200 miles on them, will they work with my LT1? Comes with the rockers, studs, and nuts. They are the non-adjustable LT4 rockers with 10mm holes for the studs. The stock LT-1 heads are 3/8th's, aren't they? That's VERY slightly off....
The 10mm and 3/8th" part is only referring to the part that sticks out, not where it screws into the head. You should be just fine with the rockers and studs.
Good luck, |
I have been told and have read that I need new spring in order to use these.. any recommendations on what type?
[This message has been edited by Glock'94 (edited 07-25-2001).] |
You can get away with the stock springs, but it is always advisable to get new ones if the stock ones have a low of miles. Comp Cams makes a good set for a decent price.
My concern was, can he run roller rockers with everything else stock LT-1. I was under the impression if you ran roller rockers you had to have specific parts that went with them. What do I know? Can anyone specifically answer this?
[/color] [This message has been edited by 95-383 (edited 07-25-2001).] [This message has been edited by 95-383 (edited 07-25-2001).] [This message has been edited by 95-383 (edited 07-25-2001).] |
I replaced the stock rockers on my Impala with the GMPP adjustable rockers. I used the stock push rods, lifters and valves. The only things I replaced were the rockers and the springs, I even used the stock retainers. BTW, if I was doing 1.6 rockers with a stock LT1 vette cam, I'd look for some LT4 springs. Plenty of chances to purchase them cheap here on the forum, I got a brand new set for $75 (actully, it was $150 for a set of new LT4 springs and a used LT1 intake manifold).
http://my.voyager.net/~danstrom/rockers.jpg |
[/color] [This message has been edited by Glock'94 (edited 07-26-2001).] |
Originally Posted by Glock'94:
[B The LT1 and LT4 comes with a roller cam, lifters, and rockers already. 1.6's would just be chaning the amount of travel by the rocker, vavles, and springs.
[/B][/color] Someone else help us here? |
