Rarely seen Corvette item....
Old Jul 11, 2016 | 12:48 PM
Patsgarage's Avatar
Patsgarage
Default Rarely seen Corvette item....
....a spare tire !
I got a flat pulling out of the driveway on drive your Vette to work day and was running late so I just parked it. I finally got around to putting on the spare yesterday.
I have to say I was impressed, I doubt the spare had seen daylight since it was put there at Bowling Green way back in 1989 and it still had 20psi of air in it.
Dumb question though, how are you supposed to get the spare down on the side of the road if the lug wrench is stored inside it ?
I used a socket to lower the spare in the driveway, but I don't think most of us carry one in the car.
Old Jul 11, 2016 | 01:05 PM
Dt86's Avatar
Dt86
You are brave, lol. Not sure I'd trust mine.
Old Jul 11, 2016 | 01:22 PM
Patsgarage's Avatar
Patsgarage
I'm not planning on driving on it, just wanted to be able to move it around until I can get new rear tires.
Old Jul 11, 2016 | 01:25 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
My 89 had the wrench on floor behind the drivers seat. Move the seat forward and look down, it's locked into place with butterfly screw and bracket.
Old Jul 11, 2016 | 01:28 PM
Patsgarage's Avatar
Patsgarage
I will have to look, mine is a Vert but they all should be the same I would think. Or I could just RTFM but asking you guys is much more fun.
Old Jul 11, 2016 | 02:58 PM
Richard Raichert's Avatar
Richard Raichert
Default 94 Vert
Same on my 94 Vert
Old Jul 11, 2016 | 03:25 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
My buddy got a flat the other day on his 90 and the spare was flat. The situation of the flat will make you cringe !!
He was driving down the road and didn't realize he hit a rubber bungee cord. The "S" hook went into and through the belts of the tire and caused a flat, but that wasn't the worst part. The other end of the bungee cord beat the side of the car up until he was able to get over and stopped. It put several gouges down into the actual fiberglass.
Old Jul 11, 2016 | 03:41 PM
Dt86's Avatar
Dt86
What mine looked like when I got it. I don't think it seen daylight, ever, before that. And it was flat.
After clean up and air. Still holding air.
Old Jul 11, 2016 | 08:45 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Something to consider when using the space saver spare on the rear.
Drive to far or fast and you'll burn up the LS clutch plates.
Consider swapping it to the front if possible.
Old Jul 12, 2016 | 12:22 AM
gjohnson's Avatar
gjohnson
When I dropped my original spare on my 84 it was flat but unused and the original jack was still sealed in a bag.
Old Jul 12, 2016 | 12:49 AM
Jerry Roubos's Avatar
Jerry Roubos
86 Vert lug wrench is stored under the hood on the right side.
Old Jul 12, 2016 | 05:49 AM
hcbph's Avatar
hcbph
I did something a little different too. I made up a small toolkit that includes a 3/4" socket, ratchet wrench, breaker bar and the jack from a 90's Pontiac Grand Am which I keep behind the seat. Wouldn't do too well to have everything in with the spare if you have a flat in the rear and the car is sitting on the ground. I did check the spare last year to insure it held air though I wouldn't want to go too far on it.
Old Jul 12, 2016 | 02:06 PM
dayle97se's Avatar
dayle97se
C4 of Year Finalist (appearance mods) 2019
I believe I read on CF that there is a fullsize spare from a newer GM car (a GTO maybe?) that fits our C4 with little to no modification. Can anyone confirm what GM car full size spare Im referring to?
Old Jul 12, 2016 | 08:33 PM
CREWZIN's Avatar
CREWZIN
I've had to use mine....
Old Nov 20, 2016 | 06:04 PM
loknload's Avatar
loknload
After seeing this I think I need to drop and check mine, been there since new and I've never seen it!
Old Nov 20, 2016 | 06:19 PM
Raidmagic's Avatar
Raidmagic
Mine is out back by the shed, hasn't been under the car in at least 15 years
Old Nov 21, 2016 | 05:48 PM
Wendell Allen's Avatar
Wendell Allen
Like Dewayne Johnson (aka The Rock) with a wooden peg leg.
To Rarely seen Corvette item....
Old Nov 22, 2016 | 01:13 PM
LapU's Avatar
LapU
Where would one pick one up is one wanted one? Aside from the junkyard.
Old Nov 23, 2016 | 12:31 AM
GILSWHO's Avatar
GILSWHO
Default Tire wrench
On an 84 the tire wrench is under the hood above the radiator.
Old Nov 23, 2016 | 11:34 AM
mickey5's Avatar
mickey5
flat bed tows are standard on most insurance policies these days. Just call and take it to a tire shop. Many new cars today don't come with a spare. My '05 Chevy SSR only came with a plug in air pump and a can of sealer.
